Kombustor on RTX 3060 12G -> "no PhysX GPU support"
Started by Max Dralle, October 07, 2021, 12:23:40 PM
Max Dralle
Hi all.
Long time lurker, first time poster.
I installed my new Gigabyte RTX 3060 Vision OC 12G (rev. 2.0) and started fiddling with the clocks using Afterburner (v4.6.4 beta4)
For stability checks I use the latest Kombuter (v4.1.13.0 x64) and all seemed normal, until I started trying the PhysX tests.
As the titel says, the PhysX GPU tests fail and a popup window states
QuoteUnable to start the graphics test.
No PhysX GPU support.
Fluidmark 1.5.4 is running fine though.
I'd greatly appreciate, if this could be fixed... :)
TIA and keep up the good work!
Max
What does c:\Program Files\Geeks3D\MSI Kombustor 4 x64\_kombustor_log.txt read?
Max Dralle
Thanks for getting back at me
(12:14:26:162) MSI Kombustor v4.1.13.0
(12:14:26:162) MSI graphics card stress test and benchmarking utility.
(12:14:26:162) Homepage: https://geeks3d.com/furmark/kombustor/
(12:14:26:162) home directory: C:\Program Files\Tools\MSI Kombustor 4 x64\
(12:14:26:162) log file path: C:\Program Files\Tools\MSI Kombustor 4 x64\_kombustor_log.txt
(12:14:26:162) Windows version: Windows 10 build 18363
(12:14:26:162) [stb] STB image loader. Supported formats: *.JPEG, *.PNG, *.TGA, *.BMP, *.PSD, *.GIF, *.HDR, *.PIC
(12:14:26:162) [tinyexr] EXR image loader.
(12:14:26:162) [lib3ds] Lib3ds loader (core plugin).
(12:14:26:162) [ObjLoaderV1] OBJ 3D loader (core plugin).
(12:14:26:162) [ObjLoaderV2] OBJ loader based on Tiny OBJ Loader (core plugin).
(12:14:26:163) [STL] STL (StereoLithography) 3D loader (core plugin).
(12:14:26:163) [glTF] glTF 3D loader (core plugin).
(12:14:26:163) [SQLite3] SQLite3 version 3.36.0
(12:14:26:163) GraphX Core 0.42.0.0 (codename: Iridium) initialization ok.
(12:14:26:163) GeeXLab dir => C:\Program Files\Tools\MSI Kombustor 4 x64\geexlab/
(12:14:26:163) plugins search path: C:\Program Files\Tools\MSI Kombustor 4 x64\plugins/;
(12:14:26:166) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(12:14:26:193) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(12:14:26:219) [Vulkan2] VK_KHR_device_group_creation supported.
(12:14:26:220) [Vulkan2] PhysicalDeviceGroupCount: 1
(12:14:26:222) [Vulkan2] - PhysicalDeviceGroup[0]:
(12:14:26:222) [Vulkan2]   -- physicalDeviceCount: 1
(12:14:26:222) [Vulkan2]   ---- physicalDevices[0] pointer: 0xFBD703B0
(12:14:26:222) [Vulkan2] # Vulkan devices: 1
(12:14:26:222) [Vulkan2] [ GPU 0 ]--------------------------------------
(12:14:26:222) [Vulkan2] - physical device pointer: 0xFBD703B0
(12:14:26:222) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(12:14:26:222) [Vulkan2] - DeviceID: 10DE-2504
(12:14:26:222) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(12:14:26:222) [Vulkan2] - Vulkan API version: 1.2.175
(12:14:26:222) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(12:14:26:223) plugin plugin_gxc_vulkan2 loaded ok
(12:14:26:224) [GpuMonitor] Operating system detected: Windows 10 build 18363
(12:14:26:228) [GpuMonitor] Num physical GPU(s): 1
(12:14:26:228) [GpuMonitor] Num logical GPU(s): 1
(12:14:26:252) [GpuMonitor] Num GPUs found: 1
(12:14:26:252) [GpuMonitor] GPU0 - NVIDIA GeForce RTX 3060
(12:14:26:252) [GpuMonitor] GPU0 - PCI codes: 0x10DE-0x2504
(12:14:26:252) [GpuMonitor] GPU0 - BIOS: 94.06.25.00.80
(12:14:26:252) [GpuMonitor] GPU0 - core temperature: 31 degC
(12:14:26:252) [GpuMonitor] GPU0 - driver: 472.12
(12:14:26:252) plugin plugin_gxc_gpumon loaded ok
(12:14:26:480) VSYNC status: -1
(12:14:26:482) [Assimp] ASSIMP 3D object loader plugin.
(12:14:26:482) [Assimp] version: 5.0.0
(12:14:26:482) [Assimp] supported 3D formats: *.3d;*.3ds;*.3mf;*.a3d;*.ac;*.ac3d;*.acc;*.amf;*.ase;*.ask;*.assbin;*.b3d;*.blend;*.bsp;*.bvh;*.cob;*.csm;*.dae;*.dxf;*.enff;*.fbx;*.glb;*.gltf;*.hmp;*.ifc;*.ifczip;*.irr;*.irrmesh;*.lwo;*.lws;*.lxo;*.m3d;*.md2;*.md3;*.md5anim;*.md5camera;*.md5mesh;*.mdc;*.mdl;*.mesh;*.mesh.xml;*.mot;*.ms3d;*.ndo;*.nff;*.obj;*.off;*.ogex;*.pk3;*.ply;*.pmx;*.prj;*.q3o;*.q3s;*.raw;*.scn;*.sib;*.smd;*.step;*.stl;*.stp;*.ter;*.uc;*.vta;*.x;*.xgl;*.xml;*.zae;*.zgl
(12:14:26:482) plugin plugin_gxc_assimp loaded ok
(12:14:26:489) [ImageMagick] ImageMagick plugin: create, edit, compose, or convert bitmap images, read and write images in a variety of formats (over 200) including PNG, JPEG, JPEG-2000, GIF, TIFF, DPX, EXR, WebP, Postscript, PDF, and SVG....
(12:14:26:491) [ImageMagick] ImageMagick version  ImageMagick 7.0.10-10 Q16 x64 2020-05-07 http://www.imagemagick.org
(12:14:26:491) [ImageMagick] Image formats:
(12:14:26:492) [ImageMagick] 3FR
(12:14:26:492) [ImageMagick] 3G2 3GP A AAI AI ART ARW AVI AVS B
(12:14:26:492) [ImageMagick] BGR BGRA BGRO BMP BMP2 BMP3 BRF C CAL CALS
(12:14:26:492) [ImageMagick] CANVAS CAPTION CIN CIP CLIP CLIPBOARD CMYK CMYKA CR2 CR3
(12:14:26:492) [ImageMagick] CRW CUBE CUR CUT DATA DCM DCR DCRAW DCX DDS
(12:14:26:492) [ImageMagick] DFONT DNG DPX DXT1 DXT5 EMF EPDF EPI EPS EPS2
(12:14:26:492) [ImageMagick] EPS3 EPSF EPSI EPT EPT2 EPT3 ERF EXR FAX FILE
(12:14:26:492) [ImageMagick] FITS FLIF FLV FRACTAL FTP FTS G G3 G4 GIF
(12:14:26:492) [ImageMagick] GIF87 GRADIENT GRAY GRAYA GROUP4 HALD HDR HEIC HISTOGRAM HRZ
(12:14:26:492) [ImageMagick] HTM HTML HTTP HTTPS ICB ICO ICON IIQ INFO INLINE
(12:14:26:492) [ImageMagick] IPL ISOBRL ISOBRL6 J2C J2K JNG JNX JP2 JPC JPE
(12:14:26:492) [ImageMagick] JPEG JPG JPM JPS JPT JSON K K25 KDC LABEL
(12:14:26:492) [ImageMagick] M M2V M4V MAC MAP MASK MAT MATTE MEF MIFF
(12:14:26:492) [ImageMagick] MKV MNG MONO MOV MP4 MPC MPEG MPG MRW MSL
(12:14:26:492) [ImageMagick] MSVG MTV MVG NEF NRW NULL O ORF OTB OTF
(12:14:26:492) [ImageMagick] PAL PALM PAM PANGO PATTERN PBM PCD PCDS PCL PCT
(12:14:26:492) [ImageMagick] PCX PDB PDF PDFA PEF PES PFA PFB PFM PGM
(12:14:26:492) [ImageMagick] PGX PICON PICT PIX PJPEG PLASMA PNG PNG00 PNG24 PNG32
(12:14:26:492) [ImageMagick] PNG48 PNG64 PNG8 PNM POCKETMOD PPM PS PS2 PS3 PSB
(12:14:26:492) [ImageMagick] PSD PTIF PWP R RADIAL-GRADIENT RAF RAS RAW RGB RGB565
(12:14:26:492) [ImageMagick] RGBA RGBO RGF RLA RLE RMF RW2 SCR SCREENSHOT SCT
(12:14:26:492) [ImageMagick] SFW SGI SHTML SIX SIXEL SPARSE-COLOR SR2 SRF STEGANO SUN
(12:14:26:492) [ImageMagick] SVG SVGZ TEXT TGA THUMBNAIL TIFF TIFF64 TILE TIM TM2
(12:14:26:492) [ImageMagick] TTC TTF TXT UBRL UBRL6 UIL UYVY VDA VICAR VID
(12:14:26:492) [ImageMagick] VIFF VIPS VST WBMP WEBP WMF WMV WPG X3F XBM
(12:14:26:492) plugin plugin_gxc_imagemagick loaded ok
(12:14:26:493) [ArtifactScanner] Artifact scanning for GPU overclocking.
(12:14:26:493) plugin plugin_gxc_as loaded ok
(12:14:26:493) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(12:14:26:503) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(12:14:26:508) [Vulkan2] VK_KHR_device_group_creation supported.
(12:14:26:510) [Vulkan2] PhysicalDeviceGroupCount: 1
(12:14:26:511) [Vulkan2] - PhysicalDeviceGroup[0]:
(12:14:26:511) [Vulkan2]   -- physicalDeviceCount: 1
(12:14:26:511) [Vulkan2]   ---- physicalDevices[0] pointer: 0xFBD7F9E0
(12:14:26:511) [Vulkan2] # Vulkan devices: 1
(12:14:26:511) [Vulkan2] [ GPU 0 ]--------------------------------------
(12:14:26:511) [Vulkan2] - physical device pointer: 0xFBD7F9E0
(12:14:26:511) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(12:14:26:511) [Vulkan2] - DeviceID: 10DE-2504
(12:14:26:511) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(12:14:26:511) [Vulkan2] - Vulkan API version: 1.2.175
(12:14:26:511) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(12:14:26:512) [Vulkan2] --- initializing GPU 0...
(12:14:26:886) [Vulkan2] - VK_NV_ray_tracing:
(12:14:26:886) [Vulkan2]   - shaderGroupHandleSize => 32
(12:14:26:886) [Vulkan2]   - maxRecursionDepth => 31
(12:14:26:886) [Vulkan2]   - maxShaderGroupStride => 4096
(12:14:26:886) [Vulkan2]   - shaderGroupBaseAlignment => 64
(12:14:26:886) [Vulkan2]   - maxGeometryCount => 16777215
(12:14:26:886) [Vulkan2]   - maxInstanceCount => 16777215
(12:14:26:886) [Vulkan2]   - maxTriangleCount => 536870911
(12:14:26:886) [Vulkan2]   - maxDescriptorSetAccelerationStructures => 1048576
(12:14:26:886) [Vulkan2] - VK_KHR_ray_tracing_pipeline:
(12:14:26:886) [Vulkan2]   - shaderGroupHandleSize: 32
(12:14:26:886) [Vulkan2]   - maxRayRecursionDepth: 31
(12:14:26:886) [Vulkan2]   - maxShaderGroupStride: 4096
(12:14:26:886) [Vulkan2]   - shaderGroupBaseAlignment: 64
(12:14:26:886) [Vulkan2]   - shaderGroupHandleCaptureReplaySize: 32
(12:14:26:886) [Vulkan2]   - maxRayDispatchInvocationCount: 1073741824
(12:14:26:886) [Vulkan2]   - shaderGroupHandleAlignment: 32
(12:14:26:886) [Vulkan2]   - maxRayHitAttributeSize: 32
(12:14:26:886) [Vulkan2] - VK_KHR_acceleration_structure:
(12:14:26:886) [Vulkan2]   - maxGeometryCount: 16777215
(12:14:26:886) [Vulkan2]   - maxInstanceCount: 16777215
(12:14:26:886) [Vulkan2]   - maxPrimitiveCount: 536870911
(12:14:26:886) [Vulkan2]   - maxPerStageDescriptorAccelerationStructures: 1048576
(12:14:26:886) [Vulkan2]   - maxPerStageDescriptorUpdateAfterBindAccelerationStructures: 1048576
(12:14:26:886) [Vulkan2]   - maxDescriptorSetAccelerationStructures: 1048576
(12:14:26:886) [Vulkan2]   - maxDescriptorSetUpdateAfterBindAccelerationStructures: 1048576
(12:14:26:886) [Vulkan2]   - minAccelerationStructureScratchOffsetAlignment: 128
(12:14:26:886) [Vulkan2] - VK_NV_mesh_shader:
(12:14:26:886) [Vulkan2]   - maxDrawMeshTasksCount => 65535
(12:14:26:886) [Vulkan2]   - maxTaskWorkGroupInvocations => 32
(12:14:26:886) [Vulkan2]   - maxTaskWorkGroupSize => [32;1;1]
(12:14:26:886) [Vulkan2]   - maxTaskTotalMemorySize => 16384
(12:14:26:886) [Vulkan2]   - maxTaskOutputCount => 65535
(12:14:26:886) [Vulkan2]   - maxMeshWorkGroupInvocations => 32
(12:14:26:886) [Vulkan2]   - maxDrawMeshTasksCount => [32;1;1]
(12:14:26:886) [Vulkan2]   - maxMeshTotalMemorySize => 16384
(12:14:26:886) [Vulkan2]   - maxMeshOutputVertices => 256
(12:14:26:886) [Vulkan2]   - maxMeshOutputPrimitives => 512
(12:14:26:886) [Vulkan2]   - maxMeshMultiviewViewCount => 4
(12:14:26:887) [Vulkan2]   - meshOutputPerVertexGranularity => 32
(12:14:26:887) [Vulkan2]   - meshOutputPerPrimitiveGranularity => 32
(12:14:26:887) [Vulkan2] - VK_EXT_pci_bus_info:
(12:14:26:887) [Vulkan2]   - pciDomain => 0
(12:14:26:887) [Vulkan2]   - pciBus => 66
(12:14:26:887) [Vulkan2]   - pciDevice => 0
(12:14:26:887) [Vulkan2]   - pciFunction => 0
(12:14:26:887) [Vulkan2] - VK_KHR_driver_properties:
(12:14:26:887) [Vulkan2]   - driver name: NVIDIA
(12:14:26:887) [Vulkan2]   - driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
(12:14:26:887) [Vulkan2]   - driver conformance version: 1.2.0.6:
(12:14:26:887) [Vulkan2]   - driver info: 472.12
(12:14:26:887) [Vulkan2] --- GPU 0 initialized ok
(12:14:26:924) [GpuMonitor] Initializing GPUs list from RivaTuner data.
(12:14:26:924) [GpuMonitor] - GPU0 - NVIDIA GeForce RTX 3060
(12:14:26:924) RT - CPU: 42.2°C - 5.5%
(12:14:26:924) RT - # GPUs: 1
(12:14:26:924) RT - GPU 0: NVIDIA GeForce RTX 3060
(12:14:26:924) RT - GPU 0: 31.000 °C
(12:14:26:924) Kombustor initialization ok.
(12:14:26:925) PhysX GPU info - device name:  - CUDA cores: 0
(12:14:26:968) WMI PC model: System Product Name
(12:14:26:968) WMI BIOS name: 1203
(12:14:26:968) TDR Delay: 8 seconds
(12:14:26:968) [CHECKVERSION] checking for new version...
(12:14:28:059) [CHECKVERSION] your version of Kombustor is up to date
(12:14:38:123) Unable to start the graphics test.
(12:15:00:984) Kombustor is shutting down...
(12:15:00:993) GraphX Core stopped ok.
(12:15:00:993) Kombustor shutdown ok.
That's weird because your system looks ok, you have a RTX 3060 with recent NV driver so PhysX should be available. Let me check that issue.
Max Dralle
Thanks a lot.
Let me know, if I can be of any help.
I ran Kombustor on a test machine (Win10 21H1, RTX 3060 Ti + driver 472.12) and all PhysX demos (CPU or GPU) work fine.
Try the following things:
- fully uninstall Kombustor and re-install it
- re-install the PhysX runtimes (v9.19.0218): https://www.geeks3d.com/dl/show/10124
- try to re-install NV drivers and check the Clean Installation mode
- try an old version of Kombustor like this one (v4.1.7.0): https://www.geeks3d.com/dl/show/643
I did some changes in the PhysX management in one of the latest versions of Kombustor, that could explain your issue...
Let me know.
Max Dralle
Will do...
Just so that you know, I had an RTX 2060 in my system before and used the latest Display Driver Uninstaller to clean any driver remnants before switching cards. (boot into safe mode, cleaned drivers with option fpr automatic shutdown afterwards)
After reboot, Windows automatically installed an nVidia driver and I updated with the latest studio driver from nVs  website.
Max Dralle
Kombustor 4.1.7.0 just ran fine and updating to and 4.1.10.0 worked also very well
Here's the PhysX snippet from the log file
(12:13:17:698) [PhysX4] GPU PhysX init ok (valid CUDA context manager).
(12:13:17:698) [PhysX4] GPU PhysX - CUDA device name: NVIDIA GeForce RTX 3060
(12:13:17:698) [PhysX4] GPU PhysX - CUDA device multiprocessors: 28 @ 1837MHz
(12:13:17:698) [PhysX4] GPU PhysX - CUDA device memory size: 12288MB
(12:13:17:698) [PhysX4] GPU PhysX - Dedicated PhysX GPU: NO
(12:13:17:698) [PhysX4] GPU PhysX - SM10(G80):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM12(GT200):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM13(GT260):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM20(GF100):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM30(GK100):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM35(GK110):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM50(GM100):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM52(GM200):YES
(12:13:17:698) [PhysX4] GPU PhysX - SM60(GP100):YES
(12:13:17:703) [PhysX4] PhysX SDK v4.1.1
(12:13:17:703) [PhysX4] started ok.
(12:13:17:703) physx_device => NVIDIA GeForce RTX 3060
(12:13:17:703) num cuda cores => 28
(12:13:17:703) PhysX mode => gpu
(12:13:17:703) [PhysX4] scene creation - CPU dispatcher (num threads: 32) successfully created.
(12:13:17:824) px_scene => 251
(12:13:17:858) PhysX scene/materials/actors init ok.
(12:13:19:317) time: 1.001- frames: 537 - FPS: 537 - min: 537 - max: 537
(12:13:20:314) time: 2.001- frames: 1079 - FPS: 542 - min: 537 - max: 542
(12:13:20:646) --- QUICK STATS ------------------
(12:13:20:646) Frames rendered: 1258
(12:13:20:646) Elapsed time: 2.331 sec
(12:13:20:646) Framerate - AVG:539FPS, MIN:537FPS, MAX:542FPS
(12:13:20:646) ---------------------------------
(12:13:20:742) [PhysX4] stopped ok.
(12:13:20:742) PhysX stopped ok.
Updating to 4.1.13.0 brought back the error I originally posted
(12:16:24:700) PhysX GPU info - device name:  - CUDA cores: 0
(12:16:24:800) WMI PC model: System Product Name
(12:16:24:800) WMI BIOS name: 1203
(12:16:24:800) TDR Delay: 8 seconds
(12:16:24:800) [CHECKVERSION] checking for new version...
(12:16:25:834) [CHECKVERSION] your version of Kombustor is up to date
(12:16:31:615) Unable to start the graphics test.
HTH
Max Dralle
Hi JeGX.
I found v4.1.12.0 on the MSI Kombustor download page and the PhysX test ran fine.
https://msikombustor.com/download/
(13:13:06:168) MSI Kombustor v4.1.12.0
(13:13:06:168) MSI graphics card stress test and benchmarking utility.
(13:13:06:168) Homepage: https://geeks3d.com/furmark/kombustor/
(13:13:06:168) home directory: C:\Program Files\Tools\MSI Kombustor 4 x64\
(13:13:06:168) log file path: C:\Program Files\Tools\MSI Kombustor 4 x64\_kombustor_log.txt
(13:13:06:168) Windows version: Windows 10 build 18363
(13:13:06:168) [stb] STB image loader. Supported formats: *.JPEG, *.PNG, *.TGA, *.BMP, *.PSD, *.GIF, *.HDR, *.PIC
(13:13:06:168) [tinyexr] EXR image loader.
(13:13:06:168) [lib3ds] Lib3ds loader (core plugin).
(13:13:06:168) [ObjLoaderV1] OBJ 3D loader (core plugin).
(13:13:06:168) [ObjLoaderV2] OBJ loader based on Tiny OBJ Loader (core plugin).
(13:13:06:168) [STL] STL (StereoLithography) 3D loader (core plugin).
(13:13:06:168) [glTF] glTF 3D loader (core plugin).
(13:13:06:168) [SQLite3] SQLite3 version 3.35.5
(13:13:06:168) GraphX Core 0.41.3.0 (codename: Iridium) initialization ok.
(13:13:06:168) GeeXLab dir => C:\Program Files\Tools\MSI Kombustor 4 x64\geexlab/
(13:13:06:168) plugins search path: C:\Program Files\Tools\MSI Kombustor 4 x64\plugins/;
(13:13:06:168) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(13:13:06:204) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(13:13:06:234) [Vulkan2] VK_KHR_device_group_creation supported.
(13:13:06:234) [Vulkan2] PhysicalDeviceGroupCount: 1
(13:13:06:234) [Vulkan2] - PhysicalDeviceGroup[0]:
(13:13:06:234) [Vulkan2]   -- physicalDeviceCount: 1
(13:13:06:234) [Vulkan2]   ---- physicalDevices[0] pointer: 0x7E2E6EF0
(13:13:06:234) [Vulkan2] # Vulkan devices: 1
(13:13:06:234) [Vulkan2] [ GPU 0 ]--------------------------------------
(13:13:06:234) [Vulkan2] - physical device pointer: 0x7E2E6EF0
(13:13:06:234) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(13:13:06:234) [Vulkan2] - DeviceID: 10DE-2504
(13:13:06:234) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(13:13:06:234) [Vulkan2] - Vulkan API version: 1.2.175
(13:13:06:234) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(13:13:06:240) plugin plugin_gxc_vulkan2 loaded ok
(13:13:06:240) [GpuMonitor] Operating system detected: Windows 10 build 18363
(13:13:06:245) [GpuMonitor] Num physical GPU(s): 1
(13:13:06:245) [GpuMonitor] Num logical GPU(s): 1
(13:13:06:275) [GpuMonitor] Num GPUs found: 1
(13:13:06:275) [GpuMonitor] GPU0 - NVIDIA GeForce RTX 3060
(13:13:06:275) [GpuMonitor] GPU0 - PCI codes: 0x10DE-0x2504
(13:13:06:275) [GpuMonitor] GPU0 - BIOS: 94.06.25.00.80
(13:13:06:275) [GpuMonitor] GPU0 - core temperature: 38 degC
(13:13:06:275) [GpuMonitor] GPU0 - driver: 472.12
(13:13:06:275) plugin plugin_gxc_gpumon loaded ok
(13:13:06:495) VSYNC status: -1
(13:13:06:495) [Assimp] ASSIMP 3D object loader plugin.
(13:13:06:495) [Assimp] version: 5.0.0
(13:13:06:495) [Assimp] supported 3D formats: *.3d;*.3ds;*.3mf;*.ac;*.ac3d;*.acc;*.amf;*.ase;*.ask;*.assbin;*.b3d;*.blend;*.bvh;*.cob;*.csm;*.dae;*.dxf;*.enff;*.fbx;*.glb;*.gltf;*.hmp;*.ifc;*.ifczip;*.irr;*.irrmesh;*.lwo;*.lws;*.lxo;*.m3d;*.md2;*.md3;*.md5anim;*.md5camera;*.md5mesh;*.mdc;*.mdl;*.mesh;*.mesh.xml;*.mot;*.ms3d;*.ndo;*.nff;*.obj;*.off;*.ogex;*.pk3;*.ply;*.pmx;*.prj;*.q3o;*.q3s;*.raw;*.scn;*.sib;*.smd;*.stl;*.stp;*.ter;*.uc;*.vta;*.x;*.x3d;*.x3db;*.xgl;*.xml;*.zae;*.zgl
(13:13:06:495) plugin plugin_gxc_assimp loaded ok
(13:13:06:503) [ImageMagick] ImageMagick plugin: create, edit, compose, or convert bitmap images, read and write images in a variety of formats (over 200) including PNG, JPEG, JPEG-2000, GIF, TIFF, DPX, EXR, WebP, Postscript, PDF, and SVG....
(13:13:06:503) [ImageMagick] ImageMagick version  ImageMagick 7.0.10-10 Q16 x64 2020-05-07 http://www.imagemagick.org
(13:13:06:503) [ImageMagick] Image formats:
(13:13:06:503) [ImageMagick] 3FR
(13:13:06:503) [ImageMagick] 3G2 3GP A AAI AI ART ARW AVI AVS B
(13:13:06:503) [ImageMagick] BGR BGRA BGRO BMP BMP2 BMP3 BRF C CAL CALS
(13:13:06:503) [ImageMagick] CANVAS CAPTION CIN CIP CLIP CLIPBOARD CMYK CMYKA CR2 CR3
(13:13:06:503) [ImageMagick] CRW CUBE CUR CUT DATA DCM DCR DCRAW DCX DDS
(13:13:06:503) [ImageMagick] DFONT DNG DPX DXT1 DXT5 EMF EPDF EPI EPS EPS2
(13:13:06:503) [ImageMagick] EPS3 EPSF EPSI EPT EPT2 EPT3 ERF EXR FAX FILE
(13:13:06:503) [ImageMagick] FITS FLIF FLV FRACTAL FTP FTS G G3 G4 GIF
(13:13:06:503) [ImageMagick] GIF87 GRADIENT GRAY GRAYA GROUP4 HALD HDR HEIC HISTOGRAM HRZ
(13:13:06:503) [ImageMagick] HTM HTML HTTP HTTPS ICB ICO ICON IIQ INFO INLINE
(13:13:06:503) [ImageMagick] IPL ISOBRL ISOBRL6 J2C J2K JNG JNX JP2 JPC JPE
(13:13:06:503) [ImageMagick] JPEG JPG JPM JPS JPT JSON K K25 KDC LABEL
(13:13:06:503) [ImageMagick] M M2V M4V MAC MAP MASK MAT MATTE MEF MIFF
(13:13:06:503) [ImageMagick] MKV MNG MONO MOV MP4 MPC MPEG MPG MRW MSL
(13:13:06:503) [ImageMagick] MSVG MTV MVG NEF NRW NULL O ORF OTB OTF
(13:13:06:503) [ImageMagick] PAL PALM PAM PANGO PATTERN PBM PCD PCDS PCL PCT
(13:13:06:503) [ImageMagick] PCX PDB PDF PDFA PEF PES PFA PFB PFM PGM
(13:13:06:503) [ImageMagick] PGX PICON PICT PIX PJPEG PLASMA PNG PNG00 PNG24 PNG32
(13:13:06:503) [ImageMagick] PNG48 PNG64 PNG8 PNM POCKETMOD PPM PS PS2 PS3 PSB
(13:13:06:503) [ImageMagick] PSD PTIF PWP R RADIAL-GRADIENT RAF RAS RAW RGB RGB565
(13:13:06:503) [ImageMagick] RGBA RGBO RGF RLA RLE RMF RW2 SCR SCREENSHOT SCT
(13:13:06:503) [ImageMagick] SFW SGI SHTML SIX SIXEL SPARSE-COLOR SR2 SRF STEGANO SUN
(13:13:06:503) [ImageMagick] SVG SVGZ TEXT TGA THUMBNAIL TIFF TIFF64 TILE TIM TM2
(13:13:06:503) [ImageMagick] TTC TTF TXT UBRL UBRL6 UIL UYVY VDA VICAR VID
(13:13:06:503) [ImageMagick] VIFF VIPS VST WBMP WEBP WMF WMV WPG X3F XBM
(13:13:06:503) plugin plugin_gxc_imagemagick loaded ok
(13:13:06:508) [ArtifactScanner] Artifact scanning for GPU overclocking.
(13:13:06:508) plugin plugin_gxc_as loaded ok
(13:13:06:508) [PhysX4] NVIDIA PhysX plugin based on PhysX SDK 4.1.1
(13:13:06:508) plugin plugin_gxc_physx4 loaded ok
(13:13:06:808) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(13:13:06:818) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(13:13:06:823) [Vulkan2] VK_KHR_device_group_creation supported.
(13:13:06:823) [Vulkan2] PhysicalDeviceGroupCount: 1
(13:13:06:828) [Vulkan2] - PhysicalDeviceGroup[0]:
(13:13:06:828) [Vulkan2]   -- physicalDeviceCount: 1
(13:13:06:828) [Vulkan2]   ---- physicalDevices[0] pointer: 0x7EB4A990
(13:13:06:828) [Vulkan2] # Vulkan devices: 1
(13:13:06:828) [Vulkan2] [ GPU 0 ]--------------------------------------
(13:13:06:828) [Vulkan2] - physical device pointer: 0x7EB4A990
(13:13:06:828) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(13:13:06:828) [Vulkan2] - DeviceID: 10DE-2504
(13:13:06:828) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(13:13:06:828) [Vulkan2] - Vulkan API version: 1.2.175
(13:13:06:828) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(13:13:06:828) [Vulkan2] --- initializing GPU 0...
(13:13:07:330) [Vulkan2] - VK_NV_ray_tracing:
(13:13:07:330) [Vulkan2]   - shaderGroupHandleSize => 32
(13:13:07:330) [Vulkan2]   - maxRecursionDepth => 31
(13:13:07:330) [Vulkan2]   - maxShaderGroupStride => 4096
(13:13:07:330) [Vulkan2]   - shaderGroupBaseAlignment => 64
(13:13:07:330) [Vulkan2]   - maxGeometryCount => 16777215
(13:13:07:330) [Vulkan2]   - maxInstanceCount => 16777215
(13:13:07:330) [Vulkan2]   - maxTriangleCount => 536870911
(13:13:07:330) [Vulkan2]   - maxDescriptorSetAccelerationStructures => 1048576
(13:13:07:335) [Vulkan2] - VK_KHR_ray_tracing_pipeline:
(13:13:07:335) [Vulkan2]   - shaderGroupHandleSize: 32
(13:13:07:335) [Vulkan2]   - maxRayRecursionDepth: 31
(13:13:07:335) [Vulkan2]   - maxShaderGroupStride: 4096
(13:13:07:335) [Vulkan2]   - shaderGroupBaseAlignment: 64
(13:13:07:335) [Vulkan2]   - shaderGroupHandleCaptureReplaySize: 32
(13:13:07:335) [Vulkan2]   - maxRayDispatchInvocationCount: 1073741824
(13:13:07:335) [Vulkan2]   - shaderGroupHandleAlignment: 32
(13:13:07:335) [Vulkan2]   - maxRayHitAttributeSize: 32
(13:13:07:335) [Vulkan2] - VK_KHR_acceleration_structure:
(13:13:07:335) [Vulkan2]   - maxGeometryCount: 16777215
(13:13:07:335) [Vulkan2]   - maxInstanceCount: 16777215
(13:13:07:335) [Vulkan2]   - maxPrimitiveCount: 536870911
(13:13:07:335) [Vulkan2]   - maxPerStageDescriptorAccelerationStructures: 1048576
(13:13:07:335) [Vulkan2]   - maxPerStageDescriptorUpdateAfterBindAccelerationStructures: 1048576
(13:13:07:335) [Vulkan2]   - maxDescriptorSetAccelerationStructures: 1048576
(13:13:07:335) [Vulkan2]   - maxDescriptorSetUpdateAfterBindAccelerationStructures: 1048576
(13:13:07:335) [Vulkan2]   - minAccelerationStructureScratchOffsetAlignment: 128
(13:13:07:335) [Vulkan2] - VK_NV_mesh_shader:
(13:13:07:335) [Vulkan2]   - maxDrawMeshTasksCount => 65535
(13:13:07:335) [Vulkan2]   - maxTaskWorkGroupInvocations => 32
(13:13:07:335) [Vulkan2]   - maxTaskWorkGroupSize => [32;1;1]
(13:13:07:335) [Vulkan2]   - maxTaskTotalMemorySize => 16384
(13:13:07:335) [Vulkan2]   - maxTaskOutputCount => 65535
(13:13:07:335) [Vulkan2]   - maxMeshWorkGroupInvocations => 32
(13:13:07:335) [Vulkan2]   - maxDrawMeshTasksCount => [32;1;1]
(13:13:07:335) [Vulkan2]   - maxMeshTotalMemorySize => 16384
(13:13:07:335) [Vulkan2]   - maxMeshOutputVertices => 256
(13:13:07:335) [Vulkan2]   - maxMeshOutputPrimitives => 512
(13:13:07:335) [Vulkan2]   - maxMeshMultiviewViewCount => 4
(13:13:07:335) [Vulkan2]   - meshOutputPerVertexGranularity => 32
(13:13:07:335) [Vulkan2]   - meshOutputPerPrimitiveGranularity => 32
(13:13:07:335) [Vulkan2] - VK_EXT_pci_bus_info:
(13:13:07:335) [Vulkan2]   - pciDomain => 0
(13:13:07:335) [Vulkan2]   - pciBus => 66
(13:13:07:335) [Vulkan2]   - pciDevice => 0
(13:13:07:335) [Vulkan2]   - pciFunction => 0
(13:13:07:335) [Vulkan2] - VK_KHR_driver_properties:
(13:13:07:335) [Vulkan2]   - driver name: NVIDIA
(13:13:07:335) [Vulkan2]   - driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
(13:13:07:335) [Vulkan2]   - driver conformance version: 1.2.0.6:
(13:13:07:335) [Vulkan2]   - driver info: 472.12
(13:13:07:335) [Vulkan2] --- GPU 0 initialized ok
(13:13:07:375) Kombustor initialization ok.
(13:13:07:375) PhysX GPU info - device name => ÐJ¨ - CUDA cores => 28
(13:13:07:425) WMI PC model: System Product Name
(13:13:07:425) WMI BIOS name: 1203
(13:13:07:425) TDR Delay: 8 seconds
(13:13:07:430) [CHECKVERSION] checking for new version...
(13:13:08:469) [CHECKVERSION] a new version is available online: 4.1.13.0
(13:13:13:607) OpenGL 4.6 context created OK.
(13:13:13:607) OpenGL renderer model: NVIDIA GeForce RTX 3060/PCIe/SSE2
(13:13:13:607) OpenGL renderer vendor: NVIDIA Corporation
(13:13:13:607) OpenGL API version: 4.6.0 NVIDIA 472.12
(13:13:13:607) OpenGL info
(13:13:13:607) - GL_RENDERER: NVIDIA GeForce RTX 3060/PCIe/SSE2
(13:13:13:607) - GL_VENDOR: NVIDIA Corporation
(13:13:13:607) - GL_VERSION: 4.6.0 NVIDIA 472.12
(13:13:13:607) - GL_SHADING_LANGUAGE_VERSION: 4.60 NVIDIA
(13:13:13:607) - total GL VRAM: 12288 MB
(13:13:13:607) - available GL VRAM: 11632 MB
(13:13:13:607) - # of OpenGL extensions: 433
(13:13:13:622) [ArtifactScanner] Artifact scanning for GPU overclocking.
(13:13:13:678) [Lua] Lua version: Lua 5.1.4
(13:13:13:678) [Lua] LuaFileSystem initialized ok.
(13:13:13:678) [Lua] UTF8 initialized ok.
(13:13:13:678) [Lua] LuaSocket core initialized ok.
(13:13:13:678) [Lua] Mime core initialized ok.
(13:13:13:678) [Lua] LuaSQL SQLite3 driver initialized ok.
(13:13:13:678) [Lua] LuaGL initialized ok.
(13:13:13:678) [Lua] initialization ok.
(13:13:13:938) [PhysX4] GPU PhysX init ok (valid CUDA context manager).
(13:13:13:938) [PhysX4] GPU PhysX - CUDA device name: NVIDIA GeForce RTX 3060
(13:13:13:938) [PhysX4] GPU PhysX - CUDA device multiprocessors: 28 @ 1837MHz
(13:13:13:938) [PhysX4] GPU PhysX - CUDA device memory size: 12288MB
(13:13:13:938) [PhysX4] GPU PhysX - Dedicated PhysX GPU: NO
(13:13:13:938) [PhysX4] GPU PhysX - SM10(G80):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM12(GT200):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM13(GT260):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM20(GF100):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM30(GK100):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM35(GK110):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM50(GM100):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM52(GM200):YES
(13:13:13:938) [PhysX4] GPU PhysX - SM60(GP100):YES
(13:13:13:938) [PhysX4] PhysX SDK v4.1.1
(13:13:13:938) [PhysX4] started ok.
(13:13:13:938) physx_device => NVIDIA GeForce RTX 3060
(13:13:13:938) num cuda cores => 28
(13:13:13:938) PhysX mode => gpu
(13:13:13:938) [PhysX4] scene creation - CPU dispatcher (num threads: 32) successfully created.
(13:13:14:098) px_scene => 253
(13:13:14:133) PhysX scene/materials/actors init ok.
(13:13:15:651) time: 1.001- frames: 525 - FPS: 525 - min: 525 - max: 525
(13:13:16:657) time: 2.003- frames: 1054 - FPS: 529 - min: 525 - max: 529
(13:13:17:657) time: 3.004- frames: 1578 - FPS: 524 - min: 524 - max: 529
(13:13:18:658) time: 4.005- frames: 2100 - FPS: 522 - min: 522 - max: 529
(13:13:19:655) time: 5.005- frames: 2622 - FPS: 522 - min: 522 - max: 529
(13:13:20:657) time: 6.006- frames: 3139 - FPS: 517 - min: 517 - max: 529
(13:13:21:660) time: 7.006- frames: 3652 - FPS: 513 - min: 513 - max: 529
(13:13:22:660) time: 8.008- frames: 4163 - FPS: 511 - min: 511 - max: 529
(13:13:23:662) time: 9.008- frames: 4665 - FPS: 502 - min: 502 - max: 529
(13:13:24:659) time: 10.009- frames: 5165 - FPS: 500 - min: 500 - max: 529
(13:13:25:664) time: 11.010- frames: 5666 - FPS: 501 - min: 500 - max: 529
(13:13:26:661) time: 12.011- frames: 6166 - FPS: 500 - min: 500 - max: 529
(13:13:27:661) time: 13.011- frames: 6662 - FPS: 496 - min: 496 - max: 529
(13:13:28:662) time: 14.012- frames: 7153 - FPS: 491 - min: 491 - max: 529
(13:13:29:664) time: 15.013- frames: 7636 - FPS: 483 - min: 483 - max: 529
(13:13:30:667) time: 16.014- frames: 8117 - FPS: 481 - min: 481 - max: 529
(13:13:31:665) time: 17.015- frames: 8604 - FPS: 487 - min: 481 - max: 529
(13:13:32:666) time: 18.016- frames: 9090 - FPS: 486 - min: 481 - max: 529
(13:13:33:667) time: 19.017- frames: 9569 - FPS: 479 - min: 479 - max: 529
(13:13:34:671) time: 20.018- frames: 10046 - FPS: 477 - min: 477 - max: 529
(13:13:35:671) time: 21.019- frames: 10518 - FPS: 472 - min: 472 - max: 529
(13:13:36:673) time: 22.020- frames: 10988 - FPS: 470 - min: 470 - max: 529
(13:13:37:676) time: 23.022- frames: 11458 - FPS: 470 - min: 470 - max: 529
(13:13:38:676) time: 24.022- frames: 11927 - FPS: 469 - min: 469 - max: 529
(13:13:39:677) time: 25.024- frames: 12391 - FPS: 464 - min: 464 - max: 529
(13:13:40:678) time: 26.025- frames: 12853 - FPS: 462 - min: 462 - max: 529
(13:13:41:680) time: 27.027- frames: 13316 - FPS: 463 - min: 462 - max: 529
(13:13:42:682) time: 28.029- frames: 13773 - FPS: 457 - min: 457 - max: 529
(13:13:43:685) time: 29.031- frames: 14227 - FPS: 454 - min: 454 - max: 529
(13:13:44:685) time: 30.032- frames: 14676 - FPS: 449 - min: 449 - max: 529
(13:13:45:688) time: 31.033- frames: 15125 - FPS: 449 - min: 449 - max: 529
(13:13:46:686) time: 32.034- frames: 15571 - FPS: 446 - min: 446 - max: 529
(13:13:47:687) time: 33.035- frames: 16011 - FPS: 440 - min: 440 - max: 529
(13:13:48:688) time: 34.035- frames: 16449 - FPS: 438 - min: 438 - max: 529
(13:13:49:688) time: 35.037- frames: 16884 - FPS: 435 - min: 435 - max: 529
(13:13:50:692) time: 36.038- frames: 17317 - FPS: 433 - min: 433 - max: 529
(13:13:51:688) time: 37.039- frames: 17745 - FPS: 428 - min: 428 - max: 529
(13:13:52:693) time: 38.039- frames: 18170 - FPS: 425 - min: 425 - max: 529
(13:13:53:693) time: 39.041- frames: 18598 - FPS: 428 - min: 425 - max: 529
(13:13:54:693) time: 40.042- frames: 19022 - FPS: 424 - min: 424 - max: 529
(13:13:55:695) time: 41.043- frames: 19444 - FPS: 422 - min: 422 - max: 529
(13:13:56:697) time: 42.043- frames: 19863 - FPS: 419 - min: 419 - max: 529
(13:13:57:697) time: 43.044- frames: 20286 - FPS: 423 - min: 419 - max: 529
(13:13:58:696) time: 44.044- frames: 20707 - FPS: 421 - min: 419 - max: 529
(13:13:59:697) time: 45.044- frames: 21126 - FPS: 419 - min: 419 - max: 529
(13:14:00:698) time: 46.046- frames: 21546 - FPS: 420 - min: 419 - max: 529
(13:14:01:699) time: 47.047- frames: 21965 - FPS: 419 - min: 419 - max: 529
(13:14:02:701) time: 48.048- frames: 22387 - FPS: 422 - min: 419 - max: 529
(13:14:03:703) time: 49.049- frames: 22810 - FPS: 423 - min: 419 - max: 529
(13:14:04:704) time: 50.051- frames: 23236 - FPS: 426 - min: 419 - max: 529
(13:14:05:706) time: 51.053- frames: 23658 - FPS: 422 - min: 419 - max: 529
(13:14:06:707) time: 52.053- frames: 24077 - FPS: 419 - min: 419 - max: 529
(13:14:07:708) time: 53.055- frames: 24495 - FPS: 418 - min: 418 - max: 529
(13:14:08:705) time: 54.055- frames: 24913 - FPS: 418 - min: 418 - max: 529
(13:14:09:709) time: 55.056- frames: 25338 - FPS: 425 - min: 418 - max: 529
(13:14:10:707) time: 56.057- frames: 25761 - FPS: 423 - min: 418 - max: 529
(13:14:11:708) time: 57.057- frames: 26182 - FPS: 421 - min: 418 - max: 529
(13:14:12:710) time: 58.058- frames: 26609 - FPS: 427 - min: 418 - max: 529
(13:14:13:711) time: 59.058- frames: 27034 - FPS: 425 - min: 418 - max: 529
(13:14:14:654) -------------------------------
(13:14:14:654) score => 7843 points
(13:14:14:654) renderer => NVIDIA GeForce RTX 3060/PCIe/SSE2
(13:14:14:654) duration => 60000 ms
(13:14:14:654) resolution => 1920x1080
(13:14:14:654) average framerate => 457 FPS
(13:14:14:654) average simrate => 41 SPS
(13:14:14:654) PhysX device => NVIDIA GeForce RTX 3060
(13:14:14:708) time: 60.058- frames: 27457 - FPS: 423 - min: 418 - max: 529
(13:14:15:714) time: 61.060- frames: 27876 - FPS: 419 - min: 418 - max: 529
(13:14:16:714) time: 62.060- frames: 28296 - FPS: 420 - min: 418 - max: 529
(13:14:17:715) time: 63.061- frames: 28718 - FPS: 422 - min: 418 - max: 529
(13:14:18:715) time: 64.062- frames: 29139 - FPS: 421 - min: 418 - max: 529
(13:14:19:715) time: 65.064- frames: 29564 - FPS: 425 - min: 418 - max: 529
(13:14:20:719) time: 66.066- frames: 29986 - FPS: 422 - min: 418 - max: 529
(13:14:21:718) time: 67.068- frames: 30407 - FPS: 421 - min: 418 - max: 529
(13:14:22:722) time: 68.069- frames: 30825 - FPS: 418 - min: 418 - max: 529
(13:14:23:723) time: 69.070- frames: 31244 - FPS: 419 - min: 418 - max: 529
(13:14:24:725) time: 70.072- frames: 31666 - FPS: 422 - min: 418 - max: 529
(13:14:25:491) Submitting GPU data to Geeks3D server...
(13:14:25:723) time: 71.072- frames: 32090 - FPS: 424 - min: 418 - max: 529
(13:14:26:029) GPU database - submit OK
(13:14:26:725) time: 72.074- frames: 32511 - FPS: 421 - min: 418 - max: 529
(13:14:27:033) --- QUICK STATS ------------------
(13:14:27:033) Frames rendered: 32638
(13:14:27:033) Elapsed time: 72.377 sec
(13:14:27:033) Framerate - AVG:451FPS, MIN:418FPS, MAX:529FPS
(13:14:27:033) ---------------------------------
(13:14:27:158) [PhysX4] stopped ok.
(13:14:27:158) PhysX stopped ok.
(13:14:30:404) Kombustor is shutting down...
(13:14:30:409) GraphX Core stopped ok.
(13:14:30:409) Kombustor shutdown ok.
Be careful, msikombustor.com is not an official page (I wasn't aware of its existance) and maybe it contains malwares or repackaged versions of Kombustor. The official homepage is https://geeks3d.com/furmark/kombustor/
I will try to fix the bug if I find it...
Max Dralle
it's not clear but it looks like there 's something wrong in the PhysX loader.
NVIDIA has some PhysX DLLs here:
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common\
Try to rename the following file: PhysXDevice64.dll in _PhysXDevice64.dll for example.
Kombustor has its own version of PhysXDevice64.dll in the plugins/ folder.
Let me know.
Max Dralle
Interesting .... the v4.1.13.0 installer fails now
I haven't seen this one before... maybe because I was only updating old versions before?
Look in the task manager > processes if there is an instance of Kombustor and kill it.
Max Dralle
Ok, Installation of .13 went fine now.
Renaming PhysXDevice64.dll to _PhysXDevice64.dll didn't change anything.
(15:34:34:044) MSI Kombustor v4.1.13.0
(15:34:34:044) MSI graphics card stress test and benchmarking utility.
(15:34:34:044) Homepage: https://geeks3d.com/furmark/kombustor/
(15:34:34:044) home directory: C:\Program Files\Tools\MSI Kombustor 4 x64\
(15:34:34:044) log file path: C:\Program Files\Tools\MSI Kombustor 4 x64\_kombustor_log.txt
(15:34:34:044) Windows version: Windows 10 build 18363
(15:34:34:044) [stb] STB image loader. Supported formats: *.JPEG, *.PNG, *.TGA, *.BMP, *.PSD, *.GIF, *.HDR, *.PIC
(15:34:34:044) [tinyexr] EXR image loader.
(15:34:34:044) [lib3ds] Lib3ds loader (core plugin).
(15:34:34:044) [ObjLoaderV1] OBJ 3D loader (core plugin).
(15:34:34:044) [ObjLoaderV2] OBJ loader based on Tiny OBJ Loader (core plugin).
(15:34:34:044) [STL] STL (StereoLithography) 3D loader (core plugin).
(15:34:34:044) [glTF] glTF 3D loader (core plugin).
(15:34:34:044) [SQLite3] SQLite3 version 3.36.0
(15:34:34:044) GraphX Core 0.42.0.0 (codename: Iridium) initialization ok.
(15:34:34:044) GeeXLab dir => C:\Program Files\Tools\MSI Kombustor 4 x64\geexlab/
(15:34:34:044) plugins search path: C:\Program Files\Tools\MSI Kombustor 4 x64\plugins/;
(15:34:34:044) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(15:34:34:074) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(15:34:34:099) [Vulkan2] VK_KHR_device_group_creation supported.
(15:34:34:099) [Vulkan2] PhysicalDeviceGroupCount: 1
(15:34:34:104) [Vulkan2] - PhysicalDeviceGroup[0]:
(15:34:34:104) [Vulkan2]   -- physicalDeviceCount: 1
(15:34:34:104) [Vulkan2]   ---- physicalDevices[0] pointer: 0xEEF21D20
(15:34:34:104) [Vulkan2] # Vulkan devices: 1
(15:34:34:104) [Vulkan2] [ GPU 0 ]--------------------------------------
(15:34:34:104) [Vulkan2] - physical device pointer: 0xEEF21D20
(15:34:34:104) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(15:34:34:104) [Vulkan2] - DeviceID: 10DE-2504
(15:34:34:104) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(15:34:34:104) [Vulkan2] - Vulkan API version: 1.2.175
(15:34:34:104) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(15:34:34:104) plugin plugin_gxc_vulkan2 loaded ok
(15:34:34:104) [GpuMonitor] Operating system detected: Windows 10 build 18363
(15:34:34:109) [GpuMonitor] Num physical GPU(s): 1
(15:34:34:109) [GpuMonitor] Num logical GPU(s): 1
(15:34:34:134) [GpuMonitor] Num GPUs found: 1
(15:34:34:134) [GpuMonitor] GPU0 - NVIDIA GeForce RTX 3060
(15:34:34:134) [GpuMonitor] GPU0 - PCI codes: 0x10DE-0x2504
(15:34:34:134) [GpuMonitor] GPU0 - BIOS: 94.06.25.00.80
(15:34:34:134) [GpuMonitor] GPU0 - core temperature: 32 degC
(15:34:34:134) [GpuMonitor] GPU0 - driver: 472.12
(15:34:34:134) plugin plugin_gxc_gpumon loaded ok
(15:34:34:355) VSYNC status: -1
(15:34:34:355) [Assimp] ASSIMP 3D object loader plugin.
(15:34:34:355) [Assimp] version: 5.0.0
(15:34:34:355) [Assimp] supported 3D formats: *.3d;*.3ds;*.3mf;*.a3d;*.ac;*.ac3d;*.acc;*.amf;*.ase;*.ask;*.assbin;*.b3d;*.blend;*.bsp;*.bvh;*.cob;*.csm;*.dae;*.dxf;*.enff;*.fbx;*.glb;*.gltf;*.hmp;*.ifc;*.ifczip;*.irr;*.irrmesh;*.lwo;*.lws;*.lxo;*.m3d;*.md2;*.md3;*.md5anim;*.md5camera;*.md5mesh;*.mdc;*.mdl;*.mesh;*.mesh.xml;*.mot;*.ms3d;*.ndo;*.nff;*.obj;*.off;*.ogex;*.pk3;*.ply;*.pmx;*.prj;*.q3o;*.q3s;*.raw;*.scn;*.sib;*.smd;*.step;*.stl;*.stp;*.ter;*.uc;*.vta;*.x;*.xgl;*.xml;*.zae;*.zgl
(15:34:34:355) plugin plugin_gxc_assimp loaded ok
(15:34:34:364) [ImageMagick] ImageMagick plugin: create, edit, compose, or convert bitmap images, read and write images in a variety of formats (over 200) including PNG, JPEG, JPEG-2000, GIF, TIFF, DPX, EXR, WebP, Postscript, PDF, and SVG....
(15:34:34:364) [ImageMagick] ImageMagick version  ImageMagick 7.0.10-10 Q16 x64 2020-05-07 http://www.imagemagick.org
(15:34:34:364) [ImageMagick] Image formats:
(15:34:34:364) [ImageMagick] 3FR
(15:34:34:364) [ImageMagick] 3G2 3GP A AAI AI ART ARW AVI AVS B
(15:34:34:364) [ImageMagick] BGR BGRA BGRO BMP BMP2 BMP3 BRF C CAL CALS
(15:34:34:364) [ImageMagick] CANVAS CAPTION CIN CIP CLIP CLIPBOARD CMYK CMYKA CR2 CR3
(15:34:34:364) [ImageMagick] CRW CUBE CUR CUT DATA DCM DCR DCRAW DCX DDS
(15:34:34:364) [ImageMagick] DFONT DNG DPX DXT1 DXT5 EMF EPDF EPI EPS EPS2
(15:34:34:364) [ImageMagick] EPS3 EPSF EPSI EPT EPT2 EPT3 ERF EXR FAX FILE
(15:34:34:364) [ImageMagick] FITS FLIF FLV FRACTAL FTP FTS G G3 G4 GIF
(15:34:34:364) [ImageMagick] GIF87 GRADIENT GRAY GRAYA GROUP4 HALD HDR HEIC HISTOGRAM HRZ
(15:34:34:364) [ImageMagick] HTM HTML HTTP HTTPS ICB ICO ICON IIQ INFO INLINE
(15:34:34:364) [ImageMagick] IPL ISOBRL ISOBRL6 J2C J2K JNG JNX JP2 JPC JPE
(15:34:34:364) [ImageMagick] JPEG JPG JPM JPS JPT JSON K K25 KDC LABEL
(15:34:34:364) [ImageMagick] M M2V M4V MAC MAP MASK MAT MATTE MEF MIFF
(15:34:34:364) [ImageMagick] MKV MNG MONO MOV MP4 MPC MPEG MPG MRW MSL
(15:34:34:364) [ImageMagick] MSVG MTV MVG NEF NRW NULL O ORF OTB OTF
(15:34:34:364) [ImageMagick] PAL PALM PAM PANGO PATTERN PBM PCD PCDS PCL PCT
(15:34:34:364) [ImageMagick] PCX PDB PDF PDFA PEF PES PFA PFB PFM PGM
(15:34:34:364) [ImageMagick] PGX PICON PICT PIX PJPEG PLASMA PNG PNG00 PNG24 PNG32
(15:34:34:364) [ImageMagick] PNG48 PNG64 PNG8 PNM POCKETMOD PPM PS PS2 PS3 PSB
(15:34:34:364) [ImageMagick] PSD PTIF PWP R RADIAL-GRADIENT RAF RAS RAW RGB RGB565
(15:34:34:364) [ImageMagick] RGBA RGBO RGF RLA RLE RMF RW2 SCR SCREENSHOT SCT
(15:34:34:364) [ImageMagick] SFW SGI SHTML SIX SIXEL SPARSE-COLOR SR2 SRF STEGANO SUN
(15:34:34:364) [ImageMagick] SVG SVGZ TEXT TGA THUMBNAIL TIFF TIFF64 TILE TIM TM2
(15:34:34:364) [ImageMagick] TTC TTF TXT UBRL UBRL6 UIL UYVY VDA VICAR VID
(15:34:34:364) [ImageMagick] VIFF VIPS VST WBMP WEBP WMF WMV WPG X3F XBM
(15:34:34:364) plugin plugin_gxc_imagemagick loaded ok
(15:34:34:364) [ArtifactScanner] Artifact scanning for GPU overclocking.
(15:34:34:364) plugin plugin_gxc_as loaded ok
(15:34:34:370) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(15:34:34:375) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(15:34:34:382) [Vulkan2] VK_KHR_device_group_creation supported.
(15:34:34:385) [Vulkan2] PhysicalDeviceGroupCount: 1
(15:34:34:385) [Vulkan2] - PhysicalDeviceGroup[0]:
(15:34:34:385) [Vulkan2]   -- physicalDeviceCount: 1
(15:34:34:385) [Vulkan2]   ---- physicalDevices[0] pointer: 0xF4B70080
(15:34:34:385) [Vulkan2] # Vulkan devices: 1
(15:34:34:385) [Vulkan2] [ GPU 0 ]--------------------------------------
(15:34:34:385) [Vulkan2] - physical device pointer: 0xF4B70080
(15:34:34:385) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060
(15:34:34:385) [Vulkan2] - DeviceID: 10DE-2504
(15:34:34:385) [Vulkan2] - NVIDIA driver version: 472.12_0.0
(15:34:34:385) [Vulkan2] - Vulkan API version: 1.2.175
(15:34:34:385) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(15:34:34:385) [Vulkan2] --- initializing GPU 0...
(15:34:34:757) [Vulkan2] - VK_NV_ray_tracing:
(15:34:34:757) [Vulkan2]   - shaderGroupHandleSize => 32
(15:34:34:757) [Vulkan2]   - maxRecursionDepth => 31
(15:34:34:757) [Vulkan2]   - maxShaderGroupStride => 4096
(15:34:34:757) [Vulkan2]   - shaderGroupBaseAlignment => 64
(15:34:34:757) [Vulkan2]   - maxGeometryCount => 16777215
(15:34:34:757) [Vulkan2]   - maxInstanceCount => 16777215
(15:34:34:757) [Vulkan2]   - maxTriangleCount => 536870911
(15:34:34:757) [Vulkan2]   - maxDescriptorSetAccelerationStructures => 1048576
(15:34:34:757) [Vulkan2] - VK_KHR_ray_tracing_pipeline:
(15:34:34:757) [Vulkan2]   - shaderGroupHandleSize: 32
(15:34:34:757) [Vulkan2]   - maxRayRecursionDepth: 31
(15:34:34:757) [Vulkan2]   - maxShaderGroupStride: 4096
(15:34:34:757) [Vulkan2]   - shaderGroupBaseAlignment: 64
(15:34:34:757) [Vulkan2]   - shaderGroupHandleCaptureReplaySize: 32
(15:34:34:757) [Vulkan2]   - maxRayDispatchInvocationCount: 1073741824
(15:34:34:757) [Vulkan2]   - shaderGroupHandleAlignment: 32
(15:34:34:757) [Vulkan2]   - maxRayHitAttributeSize: 32
(15:34:34:757) [Vulkan2] - VK_KHR_acceleration_structure:
(15:34:34:757) [Vulkan2]   - maxGeometryCount: 16777215
(15:34:34:757) [Vulkan2]   - maxInstanceCount: 16777215
(15:34:34:757) [Vulkan2]   - maxPrimitiveCount: 536870911
(15:34:34:757) [Vulkan2]   - maxPerStageDescriptorAccelerationStructures: 1048576
(15:34:34:757) [Vulkan2]   - maxPerStageDescriptorUpdateAfterBindAccelerationStructures: 1048576
(15:34:34:757) [Vulkan2]   - maxDescriptorSetAccelerationStructures: 1048576
(15:34:34:757) [Vulkan2]   - maxDescriptorSetUpdateAfterBindAccelerationStructures: 1048576
(15:34:34:757) [Vulkan2]   - minAccelerationStructureScratchOffsetAlignment: 128
(15:34:34:757) [Vulkan2] - VK_NV_mesh_shader:
(15:34:34:757) [Vulkan2]   - maxDrawMeshTasksCount => 65535
(15:34:34:757) [Vulkan2]   - maxTaskWorkGroupInvocations => 32
(15:34:34:757) [Vulkan2]   - maxTaskWorkGroupSize => [32;1;1]
(15:34:34:757) [Vulkan2]   - maxTaskTotalMemorySize => 16384
(15:34:34:757) [Vulkan2]   - maxTaskOutputCount => 65535
(15:34:34:757) [Vulkan2]   - maxMeshWorkGroupInvocations => 32
(15:34:34:757) [Vulkan2]   - maxDrawMeshTasksCount => [32;1;1]
(15:34:34:757) [Vulkan2]   - maxMeshTotalMemorySize => 16384
(15:34:34:757) [Vulkan2]   - maxMeshOutputVertices => 256
(15:34:34:757) [Vulkan2]   - maxMeshOutputPrimitives => 512
(15:34:34:757) [Vulkan2]   - maxMeshMultiviewViewCount => 4
(15:34:34:757) [Vulkan2]   - meshOutputPerVertexGranularity => 32
(15:34:34:757) [Vulkan2]   - meshOutputPerPrimitiveGranularity => 32
(15:34:34:757) [Vulkan2] - VK_EXT_pci_bus_info:
(15:34:34:757) [Vulkan2]   - pciDomain => 0
(15:34:34:757) [Vulkan2]   - pciBus => 66
(15:34:34:757) [Vulkan2]   - pciDevice => 0
(15:34:34:757) [Vulkan2]   - pciFunction => 0
(15:34:34:757) [Vulkan2] - VK_KHR_driver_properties:
(15:34:34:757) [Vulkan2]   - driver name: NVIDIA
(15:34:34:757) [Vulkan2]   - driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
(15:34:34:757) [Vulkan2]   - driver conformance version: 1.2.0.6:
(15:34:34:757) [Vulkan2]   - driver info: 472.12
(15:34:34:757) [Vulkan2] --- GPU 0 initialized ok
(15:34:34:802) Kombustor initialization ok.
(15:34:34:802) PhysX GPU info - device name:  - CUDA cores: 0
(15:34:34:842) WMI PC model: System Product Name
(15:34:34:842) WMI BIOS name: 1203
(15:34:34:842) TDR Delay: 8 seconds
(15:34:34:842) [CHECKVERSION] checking for new version...
(15:34:35:879) [CHECKVERSION] your version of Kombustor is up to date
(15:34:39:791) Unable to start the graphics test.
(15:34:43:951) Kombustor is shutting down...
(15:34:43:961) GraphX Core stopped ok.
(15:34:43:961) Kombustor shutdown ok.
Can you check the content of the plugins/ folder ?
You should have
2021-10-08  03:57 PM    <DIR>          .
2021-10-08  03:57 PM    <DIR>          ..
2021-08-09  04:03 PM         5,939,712 assimp-vc142-mt.dll
2020-11-18  06:43 PM         1,028,616 nvml.dll
2021-08-09  04:59 PM         1,478,656 PhysXCommon_64.dll
2021-08-09  04:59 PM           393,216 PhysXCooking_64.dll
2021-04-23  01:50 PM           704,208 PhysXDevice64.dll
2021-08-09  04:58 PM           257,024 PhysXFoundation_64.dll
2021-04-23  01:50 PM        29,461,360 PhysXGpu_64.dll
2021-08-09  04:59 PM         1,974,272 PhysX_64.dll
2021-08-09  04:39 PM           146,432 plugin_gxc_assimp_x64.dll
2021-08-09  07:57 PM           125,952 plugin_gxc_as_x64.dll
2021-08-17  05:43 PM           466,944 plugin_gxc_gpumon_x64.dll
2021-08-09  07:43 PM        14,514,688 plugin_gxc_imagemagick_x64.dll
2021-08-10  11:39 AM           368,128 plugin_gxc_physx4_x64.dll
2021-08-09  03:12 PM           395,776 plugin_gxc_vulkan2_x64.dll
              14 File(s)     57,254,984 bytes
You have downloaded the v4.1.13 from Geeks3D, right?
According to this score, the PhysX tests of Kombustor work:
https://gpuscore.top/msi/kombustor/show.php?id=996301
You mentioned the Studio driver, could you install the regular gaming driver to check?
Max Dralle
#17
Yes, d/l from here
08.10.2021  15:37    <DIR>          .
08.10.2021  15:37    <DIR>          ..
09.08.2021  16:03         5.939.712 assimp-vc142-mt.dll
18.11.2020  18:43         1.028.616 nvml.dll
09.08.2021  16:59         1.478.656 PhysXCommon_64.dll
09.08.2021  16:59           393.216 PhysXCooking_64.dll
23.04.2021  13:50           704.208 PhysXDevice64.dll
09.08.2021  16:58           257.024 PhysXFoundation_64.dll
23.04.2021  13:50        29.461.360 PhysXGpu_64.dll
09.08.2021  16:59         1.974.272 PhysX_64.dll
09.08.2021  16:39           146.432 plugin_gxc_assimp_x64.dll
09.08.2021  19:57           125.952 plugin_gxc_as_x64.dll
17.08.2021  17:43           466.944 plugin_gxc_gpumon_x64.dll
09.08.2021  19:43        14.514.688 plugin_gxc_imagemagick_x64.dll
09.08.2021  15:12           395.776 plugin_gxc_vulkan2_x64.dll
              13 Datei(en),     56.886.856 Bytes
               2 Verzeichnis(se), 127.188.566.016 Bytes frei
seems to be missing on my end
Quote from: JeGX on October 08, 2021, 04:05:07 PM
No need for the standard driver, I just found out that the missing file gets quarantined by my antivirus (Bitdefender Endpoint Security Tools says it's Gen:Variant.Razy.900578)
[edit]
just to make sure, I verified the hashes of my downloaded file and all three are matching
[/edit]
yes, all PhysX routines are in plugin_gxc_physx4_x64.dll...
Max Dralle
Hm... any chances that you can get your file reviewed and certified / white listed?
It must have some fundamental differences compared to the versions before.
