FurMark 1.21 released
Started by JeGX, January 24, 2020, 01:02:29 PM
Windows Defender doesn't like this version
bbrks
#2
Yup, I'm getting the same thing. Had to double check the update notification was sending me to the legit site at first.
Based on other results for "Trojan:Win32/Detplock" it looks like a fairly common false-positive.
Here's a VirusTotal link for the installer:
https://www.virustotal.com/gui/file/aa7cfca548452546aa50a3e16f1c8659191e8f4382e32f08456b0ddb65310791/detection
Yes it's false positive detection. Maybe the false positive comes from the installer (inno setup). I'm trying nsis...
I built a new installer with latest NSIS 3.05 but it's not better: 4 false positives
https://www.virustotal.com/gui/file/e93bd84b1d46df81f39a70400ff768b43f04efa04791bff74421d8ae62140a7a/detection
And FurMark.exe is worse: 14 false positives
https://www.virustotal.com/gui/file/15d7aa4586b32f411c78abd8aa24521b14244ca7c235f5c8c6126ee0d68574d3/detection
I submitted FurMark.exe to BitDefender, I hope they will update their virus definition quickly.
I compiled a test version of FurMark with an old version of the NVAPI lib (430) and I got only 1 false positive:
https://www.virustotal.com/gui/file/314e47b3eaa636488bf2b34e14e08b0649446742a4171fbcb505cd358defcfc9/detection
Those antivirus make me crazy  :P
FurMark 1.21.1 has been released:
https://www.geeks3d.com/20200124/furmark-1-21-0-released/#20200323
Version 1.21.1.0 - 2020-03-23
+ added the display of GPU-Z Power Consumption and
  Chip Power Draw (AMD) in Watts.
! updated GPU-Z sensor name: "VDDC" -> "GPU Voltage".
! updated: GPU-Z 2.30
! Log file back in FurMark's folder.
A maintenance version of FurMark has been released:
https://www.geeks3d.com/20200124/furmark-1-21-0-released/#20200603
Downloads:
https://www.geeks3d.com/furmark/downloads/
Version 1.21.2.0 - 2020-06-03
+ added the display of GPU-Z Board Power Draw in Watts.
! minor bugfixes in the submit score process.
! updated: GPU-Z 2.32
! updated: GPU Shark 0.17.1.0
! updated: ZoomGPU 1.26.1 (GPU monitoring library)
FurMark 1.21.2
