GeForce GTX Zotac 1080 ti issue
Started by 964t, May 30, 2019, 11:28:16 PM
964t
Hi Guys,
because of my graphic card makes problems, I used the FurMark v1.20.5.0 to check and after only 3 minutes run an window appears with following information:
https://www.bilder-upload.eu/bild-d6a580-1559251517.png.html
Is that normal that this screen appears after 3 minutes running in UHD?
In lover resolution this window don't pops up.
Can it be that something is wrong with the card?
Thanks.
964t
ssateneth
are you hitting "benchmark" or "stress test"? stress test is unlimited time. benchmark is only a short period of time
964t
ssateneth
well you only get that screen if you did a benchmark instead of a stress test. It looks like you clicked "Preset:2160 (4K/UHD)" button instead of "GPU stress test" button.
yes, the only way to get the score box is to press on one of the benchmark buttons.
964t
Hey guys, sorry you are right  ::)
I clicked the UHD 4k button because I want to enhanced the performance for the GPU.
But I need to read how to use this app  :'(
