Author Topic: AMD Radeon Software Adrenalin Edition 19.1.1  (Read 1388 times)
« on: January 10, 2019, 09:51:49 PM »
Radeon Software Adrenalin 2019 Edition 19.1.1 Highlights
Support For
  • Fortnite™
    • Up to 4% faster performance in Fortnite (Season 7) using Radeon™ Software Adrenalin 2019 Edition 19.1.1 on the Radeon™ RX 580 graphics card than with Radeon™ Software Adrenalin Edition 18.12.3 at 1920x1080 (1080p). RS-282
    • Up to 3% faster performance in Fortnite (Season 7) using Radeon™ Software Adrenalin 2019 Edition 19.1.1 on the Radeon™ RX Vega 64 graphics card than with Radeon™ Software Adrenalin Edition 18.12.3 at 1920x1080 (1080p). RS-283
Fixed Issues
  • Virtual Super Resolution may not show up as available on some 1440p Ultra-Wide Displays.
  • Some Radeon RX Series graphics products may experience system lag when Alt+Tab is used during gameplay.
  • Radeon Settings Advisor may incorrectly suggest older versions of Radeon Software as an update.
  • Radeon Settings software update notifications may appear more often than expected.
  • Application profile settings for Radeon WattMan may not reset to default correctly when using the reset button.
  • Radeon Settings may experience a crash when clicking the restart button after a driver installation or while switching between some Radeon WattMan tabs when changing fan settings.
  • Zero RPM control may fail to enable correctly when toggled on/off in Radeon Settings.
  • Radeon ReLive gallery upload queue may sometimes fail to upload videos.
  • Radeon Settings may sometimes incorrectly display the previously installed Radeon Software version after upgrade.
  • Custom color profile options may fail to retain in game on clone or Eyefinity display setups.
  • Performance metrics overlay feature may scale incorrectly when changing resolution in game.
  • Screen tearing may be observed with Enhanced Sync enabled on Vulkan API games.
  • Some systems running multiple displays may experience mouse lag when at least one display is enabled but powered off.
  • Upgrade Advisor may intermittently fail to detect games and provide compatibility recommendations.
