FurMark 1.20.0 released
Started by JeGX, January 23, 2018, 02:38:16 PM
0 Members and 4 Guests are viewing this topic.
mikhailrokhin
There is no way to chose second and others GPU to stress-test them. Please, point me how to chose 2nd GPU ?
Thank you for development.
FurMark is an OpenGL app and only the main graphics adapter can be used. But on some systems with some drivers, you can choose another GPU.
For example on a Windows PC with several GeForce GPUs, the NVIDIA driver adds a Render OpenGL on entry in the context menu (I have a GTX 1080 and a GT 1030 in my dev system):
Notebooks with Intel iGPU and GeForce dGPU have similar context menu entry.
mikhailrokhin
But!) On "GPU Caps Viewer" and "TechPowerUp GPU-Z" there is option to chose whether integrated GPU or additional GPUs to watch tech info and run OpenGL, OpenCL, Vulkan demos.
Thank you.
geninfo
#5
After 4 or 5 passes and submits, clicking submit button crashes Furmark.
Launch
720 Benchmark
Benchmark Finishes
Submit
Close IE
OK Results
Repeat From 720
Version 1.20.0.1. Also version 1.19.1.0.
With BIOS defaults (stock); no overclock.
Build:
https://forums.evga.com/X299-Dark-Stability-Overclock-NotesInfo-m2745580.aspx
Windows Event Viewer logs:
Faulting application name: FurMark.exe, version: 1.20.0.1, time stamp: 0x5a674c9f
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x54415f44
Faulting process id: 0x210c
Faulting application start time: 0x01d3a1a16a04a6b5
Faulting application path: C:\Program Files (x86)\Geeks3D\Benchmarks\FurMark\FurMark.exe
Faulting module path: unknown
Report Id: 26a40e01-dfac-4745-8557-603fcce9926a
Faulting package full name:
Faulting package-relative application ID:
Exception code: 0xc000041d
Report Id: 9c6ece0e-54df-4fcd-a23b-2d15025b47a6
A maintenance version of FurMark has been released:
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/
Version 1.20.2.0 - 2018-12-31
+ added NVIDIA GeForce RTX (2080, 2080 Ti, 2070)
  and Titan RTX support.
+ added Radeon RX 590 support.
! in GPU monitoring log file, GPU-Z values are used when
  GPU temperature, GPU core and mem clocks are 0.
! GPU data log polling factor set to 1 (was set to 10 in
  previous versions). Now GPU data are logged every second when
  Log GPU data is checked in Settings box. This value can be
  changed in the config file (log_gpu_data_polling_factor attribute).
! updated: GPU Shark 0.12.2.0 and GPU-Z 2.16.0
! updated: ZoomGPU 1.22.2 (GPU monitoring library).
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190115
Version 1.20.3.0 - 2019-01-15
* fixed the GPU temperature reading on some Radeon GPUs like RX 400 series.
! GPU temperature spike filter is now disabled by default.
- removed support of Windows XP.
A new maintenance version of FurMark has been released:
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190116
Version 1.20.4.0 - 2019-01-16
+ added NVIDIA GeForce RTX 2060 support
! updated: GPU Shark 0.12.4.0
! updated: ZoomGPU 1.22.5 (GPU monitoring library).
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190410
Version 1.20.5.0 - 2019-04-10
+ screen saver/blanking and sleep mode are now disallowed
  when FurMark is running. Use the new command line param
  /allow_screen_saver to allow screen saver/blanking and sleep mode.
+ added support of NVIDIA GeForce GTX 1660 Ti and
  GeForce GTX 1660.
+ added partial support of AMD Radeon VII.
! updated: GPU Shark 0.13.0.0 and GPU-Z 2.18.0
! updated: ZoomGPU 1.23.0 (GPU monitoring library).
I noticed a regression under Windows Vista:
FurMark 1.20.x fails calling K32GetProcessMemoryInfo
FurMark 1.19.1 works fine.
I have no rig with Windows 7 or 8.x handy to double-check...
Maybe it's related to the fact that I removed the support of Windows XP in FurMark 1.20.3, looks like XP and Vista are the same for Microsoft's compiler...
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190606
Version 1.20.6.0 - 2019-06-06
* fixed GPU-Z sensors reading.
! updated: GPU Shark 0.13.1.0 and GPU-Z 2.21.0
! updated: ZoomGPU 1.23.1 (GPU monitoring library).
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190704
Version 1.20.7.0 - 2019-07-03
+ added support of NVIDIA GeForce RTX 2060 SUPER and
  RTX 2070 SUPER.
! updated: GPU Shark 0.14.0.0 and GPU-Z 2.22.0
! updated: ZoomGPU 1.23.2 (GPU monitoring library).
domucmayin
it error, my pc turn off when running :D ( Asus R9 290, Pwr : 550W )
Quote from: domucmayin on August 10, 2019, 07:50:12 PM
It's likely a PSU issue. Try with a more powerful PSU.
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20190822
Version 1.20.8.0 - 2019-08-22
+ added support of NVIDIA GeForce RTX 2080 SUPER and
  variants of RTX 2060/2070 SUPER.
+ added partial support of AMD Radeon RX 5700 / 5700 XT.
! removed OpenGL extensions and caps in the score submission.
! updated: GPU Shark 0.14.1.0 and GPU-Z 2.24.0
https://www.geeks3d.com/20180123/furmark-1-20-0-gpu-stress-test-download/#20191120
Version 1.20.9.0 - 2019-11-20
+ added support of NVIDIA Quadro RTX 3000/4000/5000 Mobile,
  GeForce GTX 1650 Mobile, GeForce GTX 1660 Ti Mobile,
  GeForce RTX 2060/2070/2080 Mobile, Quadro T1000/T2000 Mobile,
  and AMD Radeon RX 5500.
* fixed fan speed reading on NVIDIA GPUs.
! updated: GPU Shark 0.15.1.0
! updated: GPU-Z 2.27
! updated: ZoomGPU 1.24.2 (GPU monitoring library)
telins
Hi JeGX, is there documentation for all of the command line parameters in version 1.20? Thanks.
I wrote years ago a small doc for command line. But I really should update it. I will write a new doc with the next update of FurMark.
