Author Topic: Render Target is Texture Array  (Read 6405 times)
way2sky
« on: June 14, 2016, 10:56:38 AM »
Hi
I want to create a render target which is a texture array, which function shall I use?
The background is, I'm implementing a voxel based global illumination, and I need to render geometry into a 3d volume (2D texture array).
I've searched API and code samples but couldn't find any examples about render target array.
Thanks in advance
Re: Render Target is Texture Array
« Reply #1 on: June 17, 2016, 02:26:30 PM »
Render targets with texture 2D arrays are not supported in current GeeXLab.
But I will try to add this support in the next update (the Windows version will be updated first).
« Reply #2 on: June 19, 2016, 06:44:55 PM »
I just added the support of texture 2d array in render target. The new GeeXLab (Windows version) should be released shortly.
