Author Topic: ANY HLSL webcam effects that are MIT licensed?  (Read 5311 times)
eco_bach
« on: April 17, 2016, 02:21:43 PM »
Hi
I assume most of the demos and packs posted on geeks3d are creative commons (NON commercial use). Are there any demos that are MIT licensed?
Re: ANY HLSL webcam effects that are MIT licensed?
« Reply #1 on: April 21, 2016, 04:28:33 PM »
If the shader posted on geeks3d (shaderlib or in the posts) is a simple copy with minor modifications of another shader, you have to check the license of the original shader (there is always a link to the original shader). If the shader author is Geeks3D (there is no link to a source, except if I forgot it...), yes you can use it as you want, I don't care.  If you have a doubt, do not hesitate to use the forum.
