Flam4CUDA 0.72 available
Started by Stefan, August 06, 2009, 12:53:59 PM
Quotev.0.72
-Updated to CUDA 2.3 - you'll probably have to update your drivers.
--Cuda 2.3 now supports multi-gpu with SLI enabled at the same time - no more twiddling settings!
-Fixed issue with frames becoming darker over the course of a long animation.
-Moved the flam3 XML loader to Flam4CudaX.dll, so it's now accessible to third parties.
v.0.71
-Added transparency option for PNG sequences.
-Fixed issue with the PNG sequence folder browser - you can now save to any folder, not just folders in My Pictures.
v.0.70
-Added support for rendering animations to PNG sequences.
Get it from Sourceforge.
Unfortunately the Electric Sheep server is down atm  :(
