AMD APP 2.6 OpenCL 1.2 preview driver, Profiler and KernelAnalyzer updates
Started by Stefan, December 19, 2011, 05:05:49 PM
Downloads here: AMD Accelerated Parallel Processing (APP) SDK (formerly ATI Stream)
For some reason it still reads 1.1, but there must be a switch somewhere  ???
Number of platforms: 1
  Platform Profile: FULL_PROFILE
  Platform Version: OpenCL 1.1 AMD-APP (851.6)
  Platform Name: AMD Accelerated Parallel Processing
  Platform Vendor: Advanced Micro Devices, Inc.
  Platform Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices cl_khr_d3d10_sharing
Number of devices: 2
  Device Type: CL_DEVICE_TYPE_GPU
  Device ID: 4098
  Board name: ATI Mobility Radeon HD 5000 Series
  Max compute units: 2
  Max work items dimensions: 3
    Max work items[0]: 128
    Max work items[1]: 128
    Max work items[2]: 128
  Max work group size: 128
  Preferred vector width char: 16
  Preferred vector width short: 8
  Preferred vector width int: 4
  Preferred vector width long: 2
  Preferred vector width float: 4
  Preferred vector width double: 0
  Native vector width char: 16
  Native vector width short: 8
  Native vector width int: 4
  Native vector width long: 2
  Native vector width float: 4
  Native vector width double: 0
  Max clock frequency: 375Mhz
  Address bits: 32
  Max memory allocation: 199753728
  Image support: Yes
  Max number of images read arguments: 128
  Max number of images write arguments: 8
  Max image 2D width: 8192
  Max image 2D height: 8192
  Max image 3D width: 2048
  Max image 3D height: 2048
  Max image 3D depth: 2048
  Max samplers within kernel: 16
  Max size of kernel argument: 1024
  Alignment (bits) of base address: 2048
  Minimum alignment (bytes) for any datatype: 128
  Single precision floating point capability
    Denorms: No
    Quiet NaNs: Yes
    Round to nearest even: Yes
    Round to zero: Yes
    Round to +ve and infinity: Yes
    IEEE754-2008 fused multiply-add: Yes
  Cache type: None
  Cache line size: 0
  Cache size: 0
  Global memory size: 536870912
  Constant buffer size: 65536
  Max number of constant args: 8
  Local memory type: Scratchpad
  Local memory size: 32768
  Kernel Preferred work group size multiple: 32
  Error correction support: 0
  Unified memory for Host and Device: 0
  Profiling timer resolution: 1
  Device endianess: Little
  Available: Yes
  Compiler available: Yes
  Execution capabilities:
    Execute OpenCL kernels: Yes
    Execute native function: No
  Queue properties:
    Out-of-Order: No
    Profiling : Yes
  Platform ID: 000007FEE952DA20
  Device OpenCL C version: OpenCL C 1.1
  Driver version: CAL 1.4.1664 (VM)
  Extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_atomic_counters_32 cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing
  Device Type: CL_DEVICE_TYPE_CPU
  Device ID: 4098
  Board name:
  Max compute units: 4
    Max work items[0]: 1024
    Max work items[1]: 1024
    Max work items[2]: 1024
  Max work group size: 1024
  Max clock frequency: 2128Mhz
  Address bits: 64
  Max memory allocation: 2147483648
  Image support: Yes
  Max size of kernel argument: 4096
  Alignment (bits) of base address: 1024
    Denorms: Yes
    Quiet NaNs: Yes
    Round to zero: Yes
  Cache type: Read/Write
  Cache line size: 64
  Cache size: 32768
  Global memory size: 4083007488
  Local memory type: Global
  Kernel Preferred work group size multiple: 1
  Unified memory for Host and Device: 1
  Profiling timer resolution: 481
  Available: Yes
    Execute native function: Yes
  Queue properties:
    Out-of-Order: No
    Profiling : Yes
  Name: Intel(R) Core(TM) i3 CPU       M 330  @ 2.13GHz
  Vendor: GenuineIntel
  Driver version: 2.0
  Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_device_fission cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing
ljbade
Hmm it seems AMD has done their usual trick of messing up their downloads. All of AMD APP files are now corrupted or missing!
http://forums.amd.com/devforum/messageview.cfm?catid=390&threadid=157725&enterthread=y
