NVIDIA Quadro 261.19 WHQL - very last driver for Windows 2000
Started by Stefan, December 21, 2010, 10:15:05 AM
QuoteAnnouncement:
    * After Release 261.19, NVIDIA will no longer test and invest in Windows 2000 driver support–all associated software, drivers, and tools will not support Windows 2000. Windows XP will still be supported.
New in Release 261.19:
    * Support for Quadro 6000, Quadro 5000, Quadro 4000, Quadro 2000 and Quadro 600.
    * Adds support for OpenGL 4.0
    * ECC State
          o New page for GPUs that support ECC (error correction code). The page lets you
                + Change the Error Correction Code (ECC) state for GPUs.
                + View GPU memory details.
    * EDID Management
          o Accessible from the View System Topology page, this feature lets you:
                + View the connector information
                + Get an EDID from a connected display and save it to disk
                + Force an EDID at a connector
                + Remove a forced EDID from a connector
    * Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
    * If you would like to be notified of upcoming drivers for Windows, please subscribe to the newsletter.
Existing Support:
    * Support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
    * Supports NVIDIA SLI technology (two-way SLI) for DirectX 9, DirectX 10, and OpenGL on SLI-certified Intel X58-based motherboard based system from select OEMs.
    * Support for DDC-Ci/MCCS over the DisplayPort AUX channel.
    * 10-bits per color (10bpc) DisplayPort support for full-screen applications on supported products.
Downloads:
Driver
Tech notes
