NVIDIA GeForce driver 525.60.11 Linux
Started by Stefan, November 28, 2022, 06:05:55 PM
  • Fixed a bug which caused Dynamic Boost to not engage on certain AmpereGPU based notebooks.
  • Added support for Dynamic Boost on notebooks with AMD CPUs.
  • Improved the performance of PRIME render-offloaded applications.
  • Fixed a regression that prevented Warp & Blend from working correctly.
  • Fixed a bug that resulted in stutter when moving windows in GNOME.
  • Added support for the EGL_MESA_platform_surfaceless extension.
  • Updated the nvidia-settings control panel to prevent the creationof display layouts that exceed hardware size limitations when using the SLI Mosaic configuration page, and to display a warning if such a layout is created manually in the Display Configuration page.
  • Removed the hard dependency on GTK 2 when building nvidia-settingsfrom source. nvidia-settings may now be built with support for GTK 2 only, GTK 3 only, or both GTK 2 and GTK 3.
  • Fixed a bug which caused suspend to fail on systems running GNOME 3as a Wayland compositor with NVreg_PreserveVideoMemoryAllocations enabled.
  • Updated the open kernel modules to support Quadro Sync, Stereo,rotation in X11, and YUV 4:2:0 on Turing.
  • Updated an error message that nvidia-installer displays when kernelheader files cannot be found to print full paths for the missing files.
  • Updated nvidia-installer to use "command -v" in place of depending on"which" to determine the availability and location of certain tools.
  • Implemented support for over-the-air updates in the Proton and Wine NVIDIANGX build. This feature is disabled by default and can be enabled by setting the "PROTON_ENABLE_NGX_UPDATER" environment variable to a value of "1".
  • Updated the Vulkan driver so that the following extensions no longerdepend on nvidia-uvm.ko being loaded at runtime:
    • * VK_KHR_acceleration_structure
       * VK_KHR_deferred_host_operations
       * VK_KHR_ray_query
       * VK_KHR_ray_tracing_pipeline
       * VK_NV_cuda_kernel_launch
       * VK_NV_ray_tracing
       * VK_NV_ray_tracing_motion_blur
       * VK_NVX_binary_import
       * VK_NVX_image_view_handle
  • Updated nvidia-installer to allow use of the "--add-this-kernel"feature by non-root users.
  • Updated nvidia-installer to display a more accurate progress bar whenbuilding the kernel modules.
  • Updated nvidia-installer to display a warning message if a VulkanICD loader is not detected.
  • Reworked nvidia-installer's support for DKMS: the kernel modules willnow be optionally registered with DKMS after the installer has already built and installed them on its own. nvidia-installer will now register the kernel modules with DKMS by default when the dkms(8) utility is detected on the system.
  • Fixed a bug in the Vulkan driver which could lead to corruption ingeometry and tessellation control shaders.
  • Added a new CUDA Debugger implementation for Pascal and newerarchitectures as a part of the driver package: libcudadebugger.so (previously released separately as "CUDA GDB Developer Preview").
  • Fixed a bug that caused nvidia-settings to find incorrect fan speedranges on some GPUs.  Lower-level layers of the driver protected the hardware from programming incorrect fan speeds, so the symptom was only incorrect reporting.  Now, reporting in nvidia-settings matches what actually gets programmed in hardware.
  • Fixed a regression in 515.76 that caused blank screens and hangs whenstarting an X server on RTX 30 series GPUs in some configurations where the boot display is connected via HDMI.
  • Fixed a bug where Marvel's Spider-Man Remastered would sometimes crashwith Xid 13 errors on Turing and later.
https://de.download.nvidia.com/XFree86/Linux-x86_64/525.60.11/NVIDIA-Linux-x86_64-525.60.11.run
https://it.download.nvidia.com/XFree86/aarch64/525.60.11/NVIDIA-Linux-aarch64-525.60.11.run
https://fr.download.nvidia.com/XFree86/FreeBSD-x86_64/525.60.11/NVIDIA-FreeBSD-x86_64-525.60.11.tar.xz
https://pl.download.nvidia.com/solaris/525.60.11/NVIDIA-Solaris-x86-525.60.11.run
