Issue with CF 6950s and Kmark
Started by Iredeus, March 23, 2012, 06:49:03 PM
Iredeus
Hey everyone, when I try to run kmark with my 6950s I get weird flickering rectangles on the ground, but I can play crysis 2 and bf 3 without issues. Is anyone else experiencing this issue?
Do you have the problem with one Radeon (CF disabled)?
I must say that I didn't re-tested KMark with Crossfire recently...
Iredeus
No I haven't done that yet, I will and ill post the result.
Iredeus
It still did it, it doesn't do it in anything else though.... most likely a driver issue maybe?
I will test KMark with a HD 6970 asap (during the update of Kombustor). Maybe, could you please post a screenshot of the issue if you can catch it.
Iredeus
#5
Okay, I reran KMark, I used the 720P mode but it does it for all modes. I also noticed that the clock on my first card was still in the low power state. I didn't notice it before, so it seems that crossfire isn't wroking properly, which makes me think even more that it may be a driver issue. I have cata 12.2 previews installed, and not the official release drivers because they were causing me other issues; and I have CAP 12.2 v 1 installled.
EDIT: Never mind, it shows the right clocks in 1080p mode, its just the 720p that doesn't show the right clocks. Regardless though, I have the same flickering issue no matter the settings I use.
