Furmark refuses to stress test dGPU
Started by WutWrong, December 08, 2024, 12:47:44 PM
WutWrong
I'm having issues with either a brand new GPU or Windows. I'm running Ryzen 7600 with an integrated GPU and 7900GRE dedicated GPU. I wanted to stress test my dedicated GPU with Furmark but even though the GPU is detected by the software, the whole system runs it, games run on it, Furmark keeps stressing the iGPU only.
Is there any way I can change that? :(
I've chosen the correct GPU in the main menu, when the test is running the correct gpu drop down list is shown but nonetheless Furmark loads the integrated GPU.
With furmark 2, you can try these solutions:
1/ use a Vulkan (VK) test and select the discrete GPU in the Vulkan GPUs list.
You can also start the test in command line (the discrete GPU has the index 1):
furmark --demo furmark-vk --gpu-index 1
2/ in command line, force the use of the discrete GPU with an OpenGL test:
furmark --hpgfx 1 --demo furmark-gl
