RTX 4070 issue
Started by samanthacade, January 14, 2025, 04:23:24 AM
samanthacade
Hello,
I built my first PC ever, one of the components is RTX 4070 super GPU. To be more exact it is Inno3D GeForce RTX 4070 Super Ichill X3 12GB GDDR6X.
There's one thing that is weird to me and I have no idea if that should concern me, but I noticed that during tests on Geeks3D FurMark app it shows me that I have Inno3D RTX 4070 Super Twin X2 12G which seems to be a GPU with 2 fans.
On top of that on HWMonitor app I can see only 2 fans there instead of 3. They all work (like physically) but it just looks weird to me. Is it a software problem? Or my GPU is shady? Should I even be bothered by it?
Quote from: samanthacade on January 14, 2025, 04:23:24 AMHello,
Could you please post a screenshot of either GPU Shark 2 or GPU-Z? I'd like to see the subdevice ID of your graphics card.
Quote from: samanthacade on January 14, 2025, 04:23:24 AMOn top of that on HWMonitor app I can see only 2 fans there instead of 3. They all work (like physically) but it just looks weird to me. Is it a software problem? Or my GPU is shady? Should I even be bothered by it?
It's normal, NVIDIA only exposes 2 sensors for fan speed (one for the center fan and the second for the side fans).
GPU Shark 2:
ASUS TUF RTX 4070 Ti - GPU-Z sensors
Same thing in GPU-Z:
samanthacade
#3
Quote from: nuninho1980 on January 14, 2025, 10:09:45 AMHello. :)
"INNO3D TuneIT OC & RGB Utility v3.15" Download https://www.inno3d.com/sites/default/files/2024-06/INNO3D%20TuneIT_V3.15.zip *** SPAMLINK REMOVED ***
Thanks for your answer. I got it.
McDivit
The Inno3D RTX 4070 Super Ichill X3 and Twin X2 share the same base GPU (RTX 4070 Super) but have different cooling solutions. Some software might misidentify your card due to similarities in device IDs.
You are talking to bots again.
There is a tiny spam link right from the quoted Inno3D link :P
Thanks Stefan, I hadn't seen the spam link. Will remove it.
