AMD Radeon Software Adrenalin 2020 Edition 21.6.2
Started by Stefan, June 29, 2021, 05:35:00 PM
Radeon Software Adrenalin 21.6.2 Highlights
Support For
  • DOOM Eternal™ next-gen update
    • Vulkan® Ray Tracing
Added Vulkan® Support
  • VK_EXT_custom_border_color
    • This extension allows applications to specify a custom border color for when the sampler address mode VK_SAMPLER_ADDRESS_MODE_CLAMP_TO_BORDER is used.
  • VK_KHR_shader_subgroup_uniform_control_flow
    • This extension exposes the availability of the SPV_KHR_subgroup_uniform_control_flow SPIR-V extension for shader modules use. The SPIR-V extension provides stronger guarantees that diverged subgroups will reconverge.
  • VK_EXT_color_write_enable
    • This extension allows applications to selectively enable and disable writes to output color attachments via a pipeline dynamic state. This has the potential to reduce pipeline counts for increased efficiency.
Fixed Issues
  • While playing MechWarrior 5™: Mercenaries on DirectX® 11, visual artifacts may be observed on some AMD Radeon graphics products such as Radeon RX 6000 series graphics products.
  • An error message – Error 184 – may be received after running the AMD Auto-Detect and Install Updates utility program on Windows® 7 based systems.
  • Adobe Substance 3D Painter™ may freeze while running this application on some AMD Radeon graphics products such as Radeon RX 6900.
