NVIDIA driver 265.90 WHQL Quadro
Started by Stefan, December 01, 2010, 05:15:14 PM
QuoteNew in Release 265.90:
    * Support for newly announced NVS 300
    * CUDA 3.2 for improved performance in GPU Computing applications.  See www.nvidia.com/cuda for more details.
    * NVIDIA Mosaic
          o This release introduces the new NVIDIA Mosaic Technology, supported only under Windows 7.
    * NVIDIA Control Panel Updates
          o General Interface
               1. The System Information page now shows the DirectX version supported by each GPU
               2. Added Multi-GPU Visual Indicator
          o 3D Vision / Stereoscopic 3D
               1. Added 3D Vision Pro controls for use when a 3D Vision Pro hub is connected.
               2. Added stereoscopic 3D windowed mode support for select 3D programs, including Google Earth
    * 3D Vision
          o Added support for 3DVisionLive.com Beta2
               1. Supports 3D photo sharing and viewing
    * NVIDIA Surround
          o Improved performance for 3-way and 4-way SLI configurations.
    * Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
Read more about NVS here: NVIDIA Introduces NVS Business Graphics Solutions
You might have already guessed it, clBuildProgram is broken again...
On the other hand a new OpenGL extension is exposed: GL_ARB_shading_language_include
Also there is a new section in installer file:
[NVIDIA_SetA_Devices.NTamd64.6.2] (Windows 7 SP1 i guess?)
Downloads:
http://www.nvidia.com/object/quadro-winxp-x32-265.90-driver.html
http://www.nvidia.com/object/quadro-winxp-x64-265.90-driver.html
http://www.nvidia.com/object/quadro-win7-winvista-32bit-265.90-driver.html
http://www.nvidia.com/object/quadro-win7-winvista-64bit-265.90-driver.html
