ATI GPU PerfStudio 2.1 available
Started by Stefan, January 16, 2010, 06:32:56 PM
QuoteGPU PerfStudio 2.1 is the next generation GPU Performance Analysis & Debugging Tool from AMD. It offers clear advantages to developers by cutting software development time and improving graphics quality.
GPU PerfStudio 2.1 gives developers control with seamless workflow integration. Spend more time writing code and less time debugging. Identify performance and algorithm issues early in the development cycle, and meet your quality and performance goals.
New Features:
    * Supports DX11 applications
    * Supports OpenGL 3.0 applications
    * Frame Capture (DX10, DX11)
Key Features:
    * Integrated Frame Profiler
    * Integrated Frame Debugger
    * Integrated Shader Debugger with support DirectX™ HLSL and ASM
    * Client / Server model
    * GPU PerfStudio 2.1 Client runs locally or remotely over the network
    * GPU PerfStudio 2.1 Server supports 32-bit and 64-bit applications
    * Supports DX10 and DX10.1 applications
    * No special build required for your application.
    * Customizable Client GUI, define and save your own window layouts
    * Drag and drop your application onto the server to start debugging
    * No installation required – copy and run anywhere – your settings go with you
