ATI GPU ShaderAnalyzer 1.53 available
Started by Stefan, January 12, 2010, 06:04:26 PM
QuoteGPU ShaderAnalyzer (GSA for short, pronounced Gee-Zah) is a tool for analyzing the performance of pixel and vertex shaders on ATI Radeon graphics cards. It gives you accurate performance estimates for your shaders and even allows you to view disassembly of the generated hardware shader. GPU ShaderAnalyzer can be used as a GUI tool for interactive tuning of your shaders or in command line mode to generate detailed reports. It supports DirectX9, DirectX10 & OpenGL. To analyze stream kernels (Brook+ and IL), please download a newly created tool, Stream KernelAnalyzer.
What's New in Version 1.53
    * Support for Microsoft DirectX 11.
    * Support for Catalyst™ driver 9.9-9.12.
    * Support for ATI Radeon™ HD 5870 graphics cards.
    * Support for ATI Radeon™ HD 5770 graphics cards.
    * Fixed support for IL disassembly.
    * Fixed issue with simple GLSL shaders.
