LibreHardwareMonitor 0.9.2 released
Started by JeGX, March 30, 2023, 04:59:22 PM
LibreHardwareMonitor, a fork of OpenHardwareMonitor, is a free software that can monitor the temperature sensors, fan speeds, voltages, load and clock speeds of your computer.
Changelog:
QuoteMatching solution projects target framework versions (4.7 to 4.7.2) by @dumbie in #782
Add RaptorLake and one more Alder Lake by @PhyxionNL in #815
Unify package references by @PhyxionNL in #816
Fix Gigabyte Z690 AORUS PRO sensor names. Add EC_Temp sensors. Add voltages. by @severgun in #817
Add Noise Sensors support by @severgun in #814
Add NZXT GRID+ V3 support by @severgun in #812
Check if ADL_Adapter_ID_Get exists by @PhyxionNL in #827
Cancel Context Menu if was panning by @Johen8 in #829
Drop .NET Standard by @PhyxionNL in #839
Bump System.Management from 5.0.0 to 6.0.0 by @PhyxionNL in #840
Fix some code analysis issues by @PhyxionNL in #841
Use file-scoped namespaces by @PhyxionNL in #842
Fixing-ITE-IT8628E to show up to 6 fans instead of 4 by @sp991 in #850
Add support for HX1500i by @Rem0o in #865
Do not modify enumerated tree by @ngraziano in #853
Update SMBios.cs by @MySelections in #877
Bump System.IO.Ports from 6.0.0 to 7.0.0 in /LibreHardwareMonitor by @dependabot in #873
Bump System.Management from 6.0.0 to 7.0.0 in /LibreHardwareMonitor by @dependabot in #875
Add preliminary support for Nuvoton NCT6799D by @Alexx999 in #846
Windows storage spaces by @marcadamsge in #871
Add update interval by @ntoff in #882
Added support for Asus Z790 Max Hero by @djmeijer in #894
Added preliminary support for Nuvoton NCT6686D chip #2 by @PhyxionNL in #897
Ring0 and InpOut cleanup by @PhyxionNL in #898
Use Central Package Management for NuGet 6.2+ by @pomianowski in #879
Add view menu item to clear the plot by @ntoff in #900
Bump Newtonsoft.Json from 13.0.1 to 13.0.2 in /LibreHardwareMonitor by @dependabot in #908
Add support for .NET 7 by @pomianowski in #878
add nvidia gpu memory used as percentage by @ntoff in #912
Zen 4 SMU Update by @sebastian-dev in #915
Corsair HX1000i Rev2 by @sebastian-dev in #916
Bump OxyPlot.Core from 2.1.0 to 2.1.2 in /LibreHardwareMonitor by @dependabot in #919
Bump OxyPlot.WindowsForms from 2.1.0 to 2.1.2 in /LibreHardwareMonitor by @dependabot in #920
Support for Asus PRIME Z690-A T_Sensor and Temp VRM by @mr-stocki in #927
Added code to read configured memory speed and voltage from the SMBios. by @dumbie in #932
Fix for Windows 11 22H2 (22621) incorrect total CPU load issue. by @dumbie in #933
Change "Hard Disk Drives" menu option to read "Storage Devices" by @generic-user1 in #947
Add support for ASUS Maximum Z690 Formula by @416C616E in #955
Added support for Aquacomputer Quadro controller by @bjdiss in #938
Implement support for Aqua Computer Farbwerk by @IreNox in #934
Added ASUS ROG Maximus Z690 Hero - SuperIO sensors by @WinFinn in #974
Fix crash GetReport on Linux by @asrulhadi in #980
Fix ASUS X470-I uncontrollable fans due to the wrong fan offset (fixes #802) by @VS-X in #978
Add Support IT8625E and X670E Valkyrie by @masaki9b in #982
Add support for ASRock Z790 Taichi/Z790 Taichi Carrara. by @papa12804 in #962
No sensor detection for Asrock boards. by @Rem0o in #999
Bump Newtonsoft.Json from 13.0.2 to 13.0.3 in /LibreHardwareMonitor by @dependabot in #1001
Added ROG Maximus X Hero (Wifi AC) - Super IO sensors by @WinFinn in #994
Added support for KrakenZ Devices by @sepp89117 in #1011
Linux cpu load by @asrulhadi in #981
Add support for Gigabyte's custom fan controller by @javs in #1020
Unify CPU namespace with folder by @PhyxionNL in #1023
Add support for IPMI sensors and Supermicro IPMI fan control by @PhyxionNL in #1024
- Download @ Geeks3D
- Download @ github
"librehardwaremonitor-092-geeks3d"
