GeeXLab 0.51 released
Started by JeGX, March 28, 2023, 03:06:41 PM
GeeXLab 0.51.0.0 has been released for Windows 32/64-bit and Linux 64-bit.
Release notes:
https://www.geeks3d.com/hacklab/20230327/geexlab-0-51-released/
Downloads:
https://www.geeks3d.com/geexlab/downloads/
QuoteVersion 0.51.0.0 - 2023.03.21
! (2023.03.21) updated cURL libs with cURL 8.0.1.
! (2023.03.19) Python 3: now the PYTHON_3 constant in the XML script node
  refers to the first Python 3 plugin available.
! (2023.03.15) updated with latest Dear ImGui 1.89.4 final.
! (2023.03.14) updated FFmpeg plugin with latest FFmpeg SDK 6.0.0.
! (2023.03.14) updated SQLite engine with latest version 3.41.1
! (2023.03.14) updated imspinner with latest version (2023.03.12).
! (2023.03.14) updated PhysX 5 plugin with latest PhysX 5 SDK 5.1.3.
! (2023.03.14) updated Spout plugin Spout2 SDK 2.007.009.
! (2023.03.14) updated GPU monitoring plugin with AMD ADL 17.1 and NVAPI R530.
Version 0.50.1.0 - 2023.02.20 (internal version - not released)
! (2023.02.20) updated with latest Dear ImGui 1.89.3 final.
+ (2023.02.20) added get_revision_id() to gh_gml lib.
! (2023.02.20) Python 3.11 plugin updated with latest Python 3.11.2.
* (2023.02.13) GPU monitoring: fixed detection of Radeon
  RX 5600 XT and RX 5700 XT.
Version 0.50.0.0 - 2023.02.01 (internal version - not released)
! (2023.02.01) improved compatibility with old versions
  of Windows (win7, win8).
! (2023.01.31) (Windows) plugins folder re-organized!
+ (2023.01.30) GPU monitoring: added support of GeForce
  RTX 4090/4080/4070/4060/4050 Laptop GPUs.
! (2023.01.30) improved win7 support: AdjustWindowRectExForDpi is
  loaded at runtime.
+ (2023.01.27) added knob() and toggle() widgets to gh_imgui lib.
* (2023.01.26) fixed bug in gh_imgui.begin_table(): last parameter
  was overwritten by previous param.
! (2023.01.26) updated with latest Dear ImGui 1.89.3 WIP.
+ (2023.01.26) GPU monitoring: added full monitoring support
  of Radeon RX 7900 XTX and RX 7900 XT.
+ (2023.01.26) GPU monitoring: added support of GeForce RTX 4070 Ti.
! (2023.01.26) GPU monitoring: added get_vram_usage() and
  gpu_power_get_current_value_v2() to gh_gml lib
! (2023.01.24) PhysX 4 and PhysX 5 plugin folder changed. Now
  PhysX 4/5 plugins are in plugins/physx4/ and plugins/physx5/.
+ (2023.01.24) added new PhysX 5 plugin based on PhysX 5 SDK 5.1.2.
  PhysX 5 is available on Windows 64-bit and Linux 64-bit only.
Version 0.49.4.0 - 2023.01.18 (internal version - not released)
! (2023.01.18) GPU monitoring: fixed VRAM DDR factor for AMD Radeon GPUs.
! (2023.01.11) GPU monitoring: fixed GPU usage reading for Intel Arc.
. internal version - not released
"GeeXLab - Scriptable prototyping engine (Lua, Python3, OpenGL, Vulkan)"
