[Bug report] Current clock speed swapped for 2 GPU with same name
Started by cashlo, December 24, 2022, 04:54:14 PM
cashlo
I have a 1070 and I just got another used 1070, and I used the tools to make sure it is working fine.
Curiously only the Current clock speed part seems to be swapped:
I used GPU-Z to confirm that yes, the GPU that is running at 98% is the one at 1506MHz.
Indeed there's something weird in GPU Shark. Will look at this issue as soon as possible. Thanks for the report! Could you please post a screenshot with detailed information (I'd like to see the bus ID)?
cashlo
I plugged in my old 980 and it seems pretty confused even with different model
