GPU-Z 2.51.0 released
Started by JeGX, November 18, 2022, 06:07:01 PM
GPU-Z is a lightweight utility designed to give you all information about your video card and GPU.
QuoteAdded full support for NVIDIA GeForce RTX 4080
Added BIOS save/upload support for NVIDIA GeForce RTX 4080 and 4090
Fixed wrong transistor count on GeForce RTX 4090
Added support for monitoring 16-pin power input
Fixed missing memory temperature on GeForce 40 Series
Fixed crash in Glenfly Advanced panel
DLSS Scan in Advanced Panel no longer starts automatically and lets you select the drives to scan first
When the "Stop" option is selected in DLSS Scan, properly indicate that the search has stopped
The list of Vulkan extensions is now one entry per line
The list of OpenCL extensions is now one entry per line and sorted alphabetically
Fixed negative Gather Offsets range displayed as positive integer in Vulkan info
Added support for NVIDIA GeForce RTX 3060 Ti GDDR6X, RTX 3060 (GA104-B), MX750 A, RTX A500 Laptop, RTX A4500 Embedded, Tesla T10, Quadro K5100M (GK104-B)
- Download @ Geeks3D
- Download @ TPU
#1
Zotac Gaming GeForce RTX 4090 Trinity non-OC screenshot with the incorrect transistors' number fixed and new "Memory Temperature" 😁:
Thanks for the "Memory Temperature" sensor info.
