Mismatched GPU model with GPU-Z
Started by bac123, October 31, 2022, 05:31:14 AM
bac123
I have GPU show RX 590 GME in GPU-Z
but FurMark show it as RX 580 2048SP
Judging from the driver's installer file GPU-Z reads out the SUBSYS_ID, but FurMark does not?
  C:\Downloads\amd-software-adrenalin-edition-22.10.3-win10-win11-oct28\Packages\Drivers\Display\WT6A_INF\U0384991.inf (9 Treffer)
 Zeile 1357: "%AMD6FDF.1%" = ati2mtag_Polaris10, PCI\VEN_1002&DEV_6FDF&SUBSYS_23151458&REV_EF
 Zeile 1358: "%AMD6FDF.2%" = ati2mtag_Polaris10, PCI\VEN_1002&DEV_6FDF&REV_E7
 Zeile 1359: "%AMD6FDF.3%" = ati2mtag_Polaris10, PCI\VEN_1002&DEV_6FDF&REV_EF
 Zeile 9161: AMD6FDF.1 = "AMD Radeon RX 580 2048SP"
 Zeile 9162: AMD6FDF.2 = "AMD Radeon RX590 GME"
 Zeile 9163: AMD6FDF.3 = "AMD Radeon RX 580 2048SP"
bac123
Quote from: Stefan on October 31, 2022, 07:59:37 AMJudging from the driver's installer file GPU-Z reads out the SUBSYS_ID, but FurMark does not?
Actually, i want to clarify which model is correct.
i bought RX580 2048sp and check GPU-Z it show RX590 GME 2304SP while FurMark show RX580 2048SP...
Quote from: bac123 on October 31, 2022, 08:03:16 AMActually, i want to clarify which model is correct.
Open device manager -> properties of GPU -> details -> hardware IDs
Check if it is rev_e7 or rev_ef
EDIT:
It should match the hex number in GPU-Z or in Geeks3D GPU shark
That is still no proof though.
Run some OpenCL benchmark with a results database and compare.
bac123
Quote from: Stefan on October 31, 2022, 08:40:59 AM
EDIT:
Where to check hex number in GPU Shark?
Quote from: bac123 on October 31, 2022, 12:42:49 PMWhere to check hex number in GPU Shark?
Revision ID: E7 in your case
That speaks for Geeks3D's tools being correct.
bac123
#6
Quote from: Stefan on October 31, 2022, 04:15:50 PM
You mean FurMark is correct?
Doesn't E7 euqal to Rx 590 GME?
Even RX580 is correct, it should be 2304SP instead of 2048SP?
Quote from: bac123 on November 01, 2022, 03:37:54 AMYou mean FurMark is correct?
Sorry, now i confused the GPU's. You are right.
After taking a closer look at the GPU Shark screenshot i can even see both names.
I'd better leave further replies to the author...
