FurMark Test low Framerate reason
Started by AndreasHGW, October 10, 2022, 12:16:36 PM
AndreasHGW
Hello
I have some simular Windows 10 PCs:
Dell Precision T5810,T5820 with NVIDIA Qaudro M2000,P2000 and K2200 graphic card
Running the Furmark GPU test the resolution of 1920x1080, I get at some PCs a result of 25-27 fps
while other PCs have 55-57 fps.
What could be the reason for this? The PCs are not so different in performance.
That's why I don't understand why the performance is so diffent.
I also tried to install the same NVIDIA driver, but even then the framerate is so different.
Andreas
Do you get 99 or 100% GPU usage (this monitoring show - you need to use MSI Afterburner v4.6.4)?
AndreasHGW
Quote from: nuninho1980 on October 10, 2022, 12:41:59 PMDo you get 99 or 100% GPU usage (this monitoring show - you need to use MSI Afterburner v4.6.4)?
I get 99%. What does that mean?
What's different to MSI Afterburner v4.6.4?
Full GPU core and VRAM speeds + 99% GPU usage + 100% TDP are normal. :)
My EVGA GeForce GTX 980 Ti SC+ videocard -
https://i.postimg.cc/pd3Gt8k4/furmark-gtx-980-ti-sc.jpg
AndreasHGW
OK, but I still do not understand why at some of these PCs I just get 25 fps while at others >50fps
See my screenshot about furmark with GPU-Z - https://i.postimg.cc/HshQSdhS/furmark-gtx-980-ti-sc.jpg
Do you understand well? :)
Please post your screenshot... ;)
Quote from: AndreasHGW on October 10, 2022, 02:03:47 PMOK, but I still do not understand why at some of these PCs I just get 25 fps while at others >50fps
And clock speeds? How are they? NV drivers love to throttle down the core clock speed when FurMark is running.
