Blender 3.2 released
Started by Stefan, June 09, 2022, 06:25:32 PM
Blender Foundation and the online developers community are proud to present Blender 3.2. Unleash your creativity with new rendering features, painting tools, performance improvements and much more.
QuoteBlender 3.2.2
Released on August 3rd 2022, Blender 3.2.2 features the following bug fixes:
    Align Active Camera to Selected fails with ortho camera T99653
    Annotation lines doesn't start where clicked T99368
    Bones using empties as custom shapes can't be selected T99270
    Crash applying non-existent modifiers T99678
    Crash when render finishes T100049
    Crash when transform applied on multi-user image T100040
    Eternal loop reading blend file thumbnail T99711
    Fix crash loading factory settings in image paint mode rB2b83f3d5
    Fix integer overflow in thumbnail extractor T99705
    Fix Python SystemExit exceptions silently exiting rB5f7c677a
    Fix use-after-free error when handling events that close windows rB3d6f6715
    Fix: Incorrect coordinates used in BLI_rct*_isect_segment functions rBc07e9e08
    Fix: Move DRW_shgroup_add_material_resources(grp, mat) to after the null-check for grp. T99646
    Gpencil Flip strokes did not support multiframe edit T99702
    GPencil multiframe falloff is scaling wrongly in rotation T99342
    GPencil strokes cannot be edited after set origin T99979
    Light group passes do not work when shadow catcher is used T98367
    Make Principled Hair IOR input behave like other IOR sliders T99785
    New OBJ importer does not import vertices that aren't part of any face T100017
    New OBJ importer fails to import faces in some cases T99532
    New OBJ importer fails with trailing space after wrapped lines T99536
    NULL pointer free with corrupt zSTD reading T99744
    Python: restrict name-space access for restricted evaluation rBae459317
    Sculpt mode missing check for hidden active object T94633
    sculpt_update_object calls paint updates for nonpaint tools T99196
    Unable to select bones when custom shape display is disabled T99364
- https://www.blender.org/download/
- https://wiki.blender.org/wiki/Reference/Release_Notes/3.2/Corrective_Releases
Blender 3.2 New Features in LESS than Five Minutes
