Caps Viewer 1.54.0.0 may not work if system contains both NVidia & AMD Open CL
Started by Smithy, November 29, 2021, 03:39:42 PM
Smithy
Geeks3D GPU Caps Viewer 1.54.0.0 may not work correctly
if the system contains one AMD Radeon RX 580 and two NVidia
Tesla K80s. Caps Viewer recognizes either one or the other
Open CL platform, but never both at the same time.
The OpenCL tab should look similar to following screenshot
Select a platform, then change to 3D Demos tab and try the OpenCL demos.
Shared workload with both platforms at the same time does not work in GPU Caps Viewer if you meant that.
milesbolen
Quote from: Stefan on November 29, 2021, 05:40:28 PMThe OpenCL tab should look similar to following screenshot
Select a platform, then change to 3D Demos tab and try the OpenCL demos. slope game
Thanks very much for that information.
