Author Topic: Notepad++ 8.1.7 released  (Read 6463 times)
« on: October 18, 2021, 06:08:57 PM »
Notepad++ v8.1.7 bug-fixes:
1.  Fix empty file not being saved regression.
2.  Fix white flash in dark mode on CMD launch with position parameters.
3.  Enhance dark themes for some programming languages (JSON, Python & Makefile).
4.  Fix "Run macro until the end of file" command skipping the last line issue.
5.  Fix tooltip layout and position in RTL mode.
6.  Fix docking problem for dockable panel in RTL mode.
Notepad++ v8.1.6 bug-fixes:
1.  Fix NUL file-corruption issue after system shutting down brutally (power cuts).
2.  Fix session lost issue after MS update restarting Windows.
3.  Make Markdown UDL work in every dark theme.
4.  Fix file can be marked as saved even it's been deleted outside.
5.  Fix white flash on Notepad++ startup in dark mode issue.
6.  Fix status bar text display glitchy in dark mode.
7.  Fix docked window sizing problem in RTL mode.
8.  Fix floating panel movement problem in RTL mode.
9.  Fix Print GUI bug in Preferences dialog.
- Downloads @ Geeks3D
- Downloads @ notepad-plus-plus.org
- Announcement
Notepad++ 8.1.8 released
« Reply #1 on: October 21, 2021, 09:43:50 AM »
Notepad++ v8.1.8 bug-fixes:
1.  Fix config files (XML) saving performance regression.
2.  Workaround Microsoft dark mode API bug of Windows 11.
- Announcement
Notepad++ 8.1.9 released
« Reply #2 on: October 26, 2021, 05:11:12 PM »
Notepad++ v8.1.9 bug-fixes:
1.  Fix empty file with non-Unicode encoding cannot be saved issue.
2.  Fix language list in Style Configurator not being reloaded issue.
- Announcement
Notepad++ 8.1.9.1 released
« Reply #3 on: November 16, 2021, 05:43:32 PM »
Notepad++ v8.1.9.1 bug-fixes:
1.  Fix a regression of saving problem.
2.  Fix a regression of reloading false alarm from the network drive.
3.  Make Function list/Project panel/Folder as Workspace icon display correct under high DPI.
4.  Make UDL generic dark mode (working for all dark theme) possible via UDL UI.
5.  Fix phantom docked panels issue after restoring from systray.
6.  Enable backup on save (simple) feature by default (only for the new installation).
- Announcement
Notepad++ 8.1.9.2 released
« Reply #4 on: November 22, 2021, 04:36:41 PM »
Notepad++ v8.1.9.2 bug-fixes:
1.  Fix failure of erasing & saving server logs (of network drive) regression.
2.  Fix dark mode not working on Windows 10 2H22.
3.  Fix crash in regex search.
4.  Fix UDL folding breaking with delimiters issue if UNIX EOL applied.
5.  Fix UDL generic dark mode via UDL UI not working issue.
6.  Fix disabling alternative icons on tab in dark mode issue.
- Announcement
