Author Topic: Kombustor on RTX 3060 12G -> "no PhysX GPU support"  (Read 10869 times)
Max Dralle
  • Jr. Member
Re: Kombustor on RTX 3060 12G -> "no PhysX GPU support"
« Reply #20 on: October 08, 2021, 04:36:37 PM »
I found this URL for submitting false positives, but I cannot send it on my own, because it gets quarantined every time I try to access the file
https://www.bitdefender.com/submit/
« Reply #21 on: October 08, 2021, 04:42:03 PM »
Could you add an exception in bitdefender?
The only difference between both plugin_gxc_physx4_x64.dll in v4.1.13 and 4.1.12 is the PhysX SDK I used for building the DLL: PhysX 4.1.2 (kombustor 4.1.13) and PhysX 4.1.1 (kombustor 4.1.12 and previous).
« Reply #22 on: October 08, 2021, 04:49:22 PM »
I submitted kombustor 4.1.13 to bitdefender. Wait and see...
I no longer use all those antivirus (I used bitdefender, avg and avira) and their tons of false positive. Now I use Microsoft Defender and it seems to do the job right.
Max Dralle
  • Jr. Member
« Reply #23 on: October 08, 2021, 04:51:44 PM »
Nope. Sadly I can't do that, because it gets remotely admin'ed on this machine.
It was already a PITA getting the admins to setup a proper whitelist for image file extensions that I heavily use when doing my daily VFX work.
I cannot fathom how they'd react when I come up with this kind of request.
Thanks man and I hear you about those "professional" AV progs...  >:(
Max Dralle
  • Jr. Member
« Reply #24 on: November 08, 2021, 01:10:37 PM »
Just a heads up that your submission appears to have made it into Bitdefender's whitelist... :)
Your Physix GPUs tests run fine now.
Cheers!
Max
