Author Topic: Question about FurMark  (Read 5056 times)
ae0n0w
« on: September 30, 2021, 01:32:08 AM »
So I found this feature where I can start the benchmark, then press "Space" on my keyboard and it will make the "furry object" disappear. Is this option able to be used from the command line automatically or set automatically so I don't have to do it every startup?
Re: Question about FurMark
« Reply #1 on: September 30, 2021, 09:34:41 AM »
The only options are furry_object="TORUS" or furry_object="CUBE"
"0"
or "-1" would have no effect.
What are you trying to achieve?
