Author Topic: AMD Radeon Software Adrenalin 2020 Edition 21.7.2  (Read 13180 times)
« on: July 28, 2021, 03:54:24 AM »
Radeon™ Software Adrenalin 21.7.2 Highlights
Support For
  • Chernobylite™
Added Vulkan® Support
  • VK_KHR_copy_commands2
    • This extension introduces extensible versions of the Vulkan® buffer and image copy commands that can now accept extension-specific information via their copy parameters.
  • VK_EXT_extended_dynamic_state2
    • This extension allows more states to be set dynamically to reduce the number of unique pipeline state objects used by an application.
Fixed Issues
  • Game Compatibility advisor in AMD Radeon™ Software may incorrectly advise some users their CPU and/or GPU do not meet the minimum requirements to play some games. If some users are still experiencing this issue, reinstall or upgrade your driver and perform a factory reset. Learn more from AMD here on performing a factory reset.
  • If a Blue or Black screen is observed in mobile systems, temporarily disable Enhanced sign-in.
  • Resident Evil Village™ may experience an intermittent application hang or TDR on AMD Radeon™ VII graphics products in the first mission of the game.
  • A Blue or Black screen may be observed after updating to the latest Radeon™ Software when core isolation is enabled.
