Author Topic: Kombustor crashes with Windows DPI scaling enabled.  (Read 16274 times)
Gam3r01
« on: July 16, 2021, 01:14:16 PM »
Windows 10 build 19043, RTX 3060 TI, Driver 471.11.
Kombustor crashes when Windows DPI scaling is enabled and testing in fullscreen mode.
Kombustor tests will only run in fullscreen mode at native resolution when Windows DPI scaling is at 100%. Any other DPI scaling results in an exit to desktop.
Windows Resolution   Kombustor    Test   Test Resolution   Fullscreen   Result
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   3840x2160   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   2560x1440   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   1920x1080   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   1600x900   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   1365x768   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   1280x720   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   1024x576   Window   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   3840x2160   Fullscreen   Test ran
4K, 3840 x 2160   v4.1.12 may21   (GL) msi-01   2560x1440   Fullscreen   Fail, Black screen. Kombustor exit. return to desktop. Log file shows = "WM_DPICHANGED - dpi_x => 96".
On running a GL full screen test Kombustor exits with "WM_DPICHANGED - dpi_x => 96"
(12:05:55:048) MSI Kombustor v4.1.12.0
(12:05:55:048) MSI graphics card stress test and benchmarking utility.
(12:05:55:048) Homepage: https://geeks3d.com/furmark/kombustor/
(12:05:55:048) home directory: D:\Testing\MSI Kombustor v4.1.12 may21\
(12:05:55:048) log file path: D:\Testing\MSI Kombustor v4.1.12 may21\_kombustor_log.txt
(12:05:55:048) Windows version: Windows 10 build 19043
(12:05:55:048) [stb] STB image loader. Supported formats: *.JPEG, *.PNG, *.TGA, *.BMP, *.PSD, *.GIF, *.HDR, *.PIC
(12:05:55:048) [tinyexr] EXR image loader.
(12:05:55:048) [lib3ds] Lib3ds loader (core plugin).
(12:05:55:048) [ObjLoaderV1] OBJ 3D loader (core plugin).
(12:05:55:048) [ObjLoaderV2] OBJ loader based on Tiny OBJ Loader (core plugin).
(12:05:55:048) [STL] STL (StereoLithography) 3D loader (core plugin).
(12:05:55:048) [glTF] glTF 3D loader (core plugin).
(12:05:55:048) [SQLite3] SQLite3 version 3.35.5
(12:05:55:048) GraphX Core 0.41.3.0 (codename: Iridium) initialization ok.
(12:05:55:048) GeeXLab dir => D:\Testing\MSI Kombustor v4.1.12 may21\geexlab/
(12:05:55:048) plugins search path: D:\Testing\MSI Kombustor v4.1.12 may21\plugins/;
(12:05:55:048) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(12:05:55:063) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(12:05:55:086) [Vulkan2] VK_KHR_device_group_creation supported.
(12:05:55:086) [Vulkan2] PhysicalDeviceGroupCount: 1
(12:05:55:087) [Vulkan2] - PhysicalDeviceGroup[0]:
(12:05:55:087) [Vulkan2]   -- physicalDeviceCount: 1
(12:05:55:087) [Vulkan2]   ---- physicalDevices[0] pointer: 0x39AC33B0
(12:05:55:087) [Vulkan2] # Vulkan devices: 1
(12:05:55:087) [Vulkan2] [ GPU 0 ]--------------------------------------
(12:05:55:087) [Vulkan2] - physical device pointer: 0x39AC33B0
(12:05:55:087) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060 Ti
(12:05:55:087) [Vulkan2] - DeviceID: 10DE-2486
(12:05:55:087) [Vulkan2] - NVIDIA driver version: 471.11_0.0
(12:05:55:087) [Vulkan2] - Vulkan API version: 1.2.175
(12:05:55:087) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(12:05:55:088) plugin plugin_gxc_vulkan2 loaded ok
(12:05:55:089) [GpuMonitor] Operating system detected: Windows 10 build 19043
(12:05:55:091) [GpuMonitor] Num physical GPU(s): 1
(12:05:55:091) [GpuMonitor] Num logical GPU(s): 1
(12:05:55:130) [GpuMonitor] Num GPUs found: 1
(12:05:55:130) [GpuMonitor] GPU0 - NVIDIA GeForce RTX 3060 Ti
(12:05:55:130) [GpuMonitor] GPU0 - PCI codes: 0x10DE-0x2486
(12:05:55:130) [GpuMonitor] GPU0 - BIOS: 94.04.3a.40.a7
(12:05:55:130) [GpuMonitor] GPU0 - core temperature: 43 degC
(12:05:55:130) [GpuMonitor] GPU0 - driver: 471.11
(12:05:55:130) plugin plugin_gxc_gpumon loaded ok
(12:05:55:332) VSYNC status: -1
(12:05:55:332) [Assimp] ASSIMP 3D object loader plugin.
(12:05:55:332) [Assimp] version: 5.0.0
(12:05:55:332) [Assimp] supported 3D formats: *.3d;*.3ds;*.3mf;*.ac;*.ac3d;*.acc;*.amf;*.ase;*.ask;*.assbin;*.b3d;*.blend;*.bvh;*.cob;*.csm;*.dae;*.dxf;*.enff;*.fbx;*.glb;*.gltf;*.hmp;*.ifc;*.ifczip;*.irr;*.irrmesh;*.lwo;*.lws;*.lxo;*.m3d;*.md2;*.md3;*.md5anim;*.md5camera;*.md5mesh;*.mdc;*.mdl;*.mesh;*.mesh.xml;*.mot;*.ms3d;*.ndo;*.nff;*.obj;*.off;*.ogex;*.pk3;*.ply;*.pmx;*.prj;*.q3o;*.q3s;*.raw;*.scn;*.sib;*.smd;*.stl;*.stp;*.ter;*.uc;*.vta;*.x;*.x3d;*.x3db;*.xgl;*.xml;*.zae;*.zgl
(12:05:55:332) plugin plugin_gxc_assimp loaded ok
(12:05:55:332) [ImageMagick] ImageMagick plugin: create, edit, compose, or convert bitmap images, read and write images in a variety of formats (over 200) including PNG, JPEG, JPEG-2000, GIF, TIFF, DPX, EXR, WebP, Postscript, PDF, and SVG....
(12:05:55:332) [ImageMagick] ImageMagick version  ImageMagick 7.0.10-10 Q16 x64 2020-05-07 http://www.imagemagick.org
(12:05:55:332) [ImageMagick] Image formats:
(12:05:55:332) [ImageMagick] 3FR
(12:05:55:332) [ImageMagick] 3G2 3GP A AAI AI ART ARW AVI AVS B
(12:05:55:332) [ImageMagick] BGR BGRA BGRO BMP BMP2 BMP3 BRF C CAL CALS
(12:05:55:332) [ImageMagick] CANVAS CAPTION CIN CIP CLIP CLIPBOARD CMYK CMYKA CR2 CR3
(12:05:55:332) [ImageMagick] CRW CUBE CUR CUT DATA DCM DCR DCRAW DCX DDS
(12:05:55:332) [ImageMagick] DFONT DNG DPX DXT1 DXT5 EMF EPDF EPI EPS EPS2
(12:05:55:332) [ImageMagick] EPS3 EPSF EPSI EPT EPT2 EPT3 ERF EXR FAX FILE
(12:05:55:332) [ImageMagick] FITS FLIF FLV FRACTAL FTP FTS G G3 G4 GIF
(12:05:55:332) [ImageMagick] GIF87 GRADIENT GRAY GRAYA GROUP4 HALD HDR HEIC HISTOGRAM HRZ
(12:05:55:332) [ImageMagick] HTM HTML HTTP HTTPS ICB ICO ICON IIQ INFO INLINE
(12:05:55:332) [ImageMagick] IPL ISOBRL ISOBRL6 J2C J2K JNG JNX JP2 JPC JPE
(12:05:55:332) [ImageMagick] JPEG JPG JPM JPS JPT JSON K K25 KDC LABEL
(12:05:55:332) [ImageMagick] M M2V M4V MAC MAP MASK MAT MATTE MEF MIFF
(12:05:55:332) [ImageMagick] MKV MNG MONO MOV MP4 MPC MPEG MPG MRW MSL
(12:05:55:332) [ImageMagick] MSVG MTV MVG NEF NRW NULL O ORF OTB OTF
(12:05:55:332) [ImageMagick] PAL PALM PAM PANGO PATTERN PBM PCD PCDS PCL PCT
(12:05:55:332) [ImageMagick] PCX PDB PDF PDFA PEF PES PFA PFB PFM PGM
(12:05:55:332) [ImageMagick] PGX PICON PICT PIX PJPEG PLASMA PNG PNG00 PNG24 PNG32
(12:05:55:332) [ImageMagick] PNG48 PNG64 PNG8 PNM POCKETMOD PPM PS PS2 PS3 PSB
(12:05:55:332) [ImageMagick] PSD PTIF PWP R RADIAL-GRADIENT RAF RAS RAW RGB RGB565
(12:05:55:332) [ImageMagick] RGBA RGBO RGF RLA RLE RMF RW2 SCR SCREENSHOT SCT
(12:05:55:332) [ImageMagick] SFW SGI SHTML SIX SIXEL SPARSE-COLOR SR2 SRF STEGANO SUN
(12:05:55:332) [ImageMagick] SVG SVGZ TEXT TGA THUMBNAIL TIFF TIFF64 TILE TIM TM2
(12:05:55:332) [ImageMagick] TTC TTF TXT UBRL UBRL6 UIL UYVY VDA VICAR VID
(12:05:55:332) [ImageMagick] VIFF VIPS VST WBMP WEBP WMF WMV WPG X3F XBM
(12:05:55:332) plugin plugin_gxc_imagemagick loaded ok
(12:05:55:332) [ArtifactScanner] Artifact scanning for GPU overclocking.
(12:05:55:332) plugin plugin_gxc_as loaded ok
(12:05:55:332) [PhysX4] NVIDIA PhysX plugin based on PhysX SDK 4.1.1
(12:05:55:332) plugin plugin_gxc_physx4 loaded ok
(12:05:55:523) [Vulkan2] Vulkan renderer plugin (Windows, Linux)
(12:05:55:529) [Vulkan2] instance version: 4194304 (Vulkan 1.0)
(12:05:55:531) [Vulkan2] VK_KHR_device_group_creation supported.
(12:05:55:532) [Vulkan2] PhysicalDeviceGroupCount: 1
(12:05:55:533) [Vulkan2] - PhysicalDeviceGroup[0]:
(12:05:55:533) [Vulkan2]   -- physicalDeviceCount: 1
(12:05:55:533) [Vulkan2]   ---- physicalDevices[0] pointer: 0x3F1FBAC0
(12:05:55:533) [Vulkan2] # Vulkan devices: 1
(12:05:55:533) [Vulkan2] [ GPU 0 ]--------------------------------------
(12:05:55:533) [Vulkan2] - physical device pointer: 0x3F1FBAC0
(12:05:55:533) [Vulkan2] - GPU name: NVIDIA GeForce RTX 3060 Ti
(12:05:55:533) [Vulkan2] - DeviceID: 10DE-2486
(12:05:55:533) [Vulkan2] - NVIDIA driver version: 471.11_0.0
(12:05:55:533) [Vulkan2] - Vulkan API version: 1.2.175
(12:05:55:533) [Vulkan2] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
(12:05:55:534) [Vulkan2] --- initializing GPU 0...
(12:05:56:093) [Vulkan2] - VK_NV_ray_tracing:
(12:05:56:093) [Vulkan2]   - shaderGroupHandleSize => 32
(12:05:56:093) [Vulkan2]   - maxRecursionDepth => 31
(12:05:56:093) [Vulkan2]   - maxShaderGroupStride => 4096
(12:05:56:093) [Vulkan2]   - shaderGroupBaseAlignment => 64
(12:05:56:093) [Vulkan2]   - maxGeometryCount => 16777215
(12:05:56:093) [Vulkan2]   - maxInstanceCount => 16777215
(12:05:56:093) [Vulkan2]   - maxTriangleCount => 536870911
(12:05:56:093) [Vulkan2]   - maxDescriptorSetAccelerationStructures => 1048576
(12:05:56:093) [Vulkan2] - VK_KHR_ray_tracing_pipeline:
(12:05:56:093) [Vulkan2]   - shaderGroupHandleSize: 32
(12:05:56:093) [Vulkan2]   - maxRayRecursionDepth: 31
(12:05:56:093) [Vulkan2]   - maxShaderGroupStride: 4096
(12:05:56:093) [Vulkan2]   - shaderGroupBaseAlignment: 64
(12:05:56:093) [Vulkan2]   - shaderGroupHandleCaptureReplaySize: 32
(12:05:56:093) [Vulkan2]   - maxRayDispatchInvocationCount: 1073741824
(12:05:56:093) [Vulkan2]   - shaderGroupHandleAlignment: 32
(12:05:56:093) [Vulkan2]   - maxRayHitAttributeSize: 32
(12:05:56:093) [Vulkan2] - VK_KHR_acceleration_structure:
(12:05:56:093) [Vulkan2]   - maxGeometryCount: 16777215
(12:05:56:093) [Vulkan2]   - maxInstanceCount: 16777215
(12:05:56:093) [Vulkan2]   - maxPrimitiveCount: 536870911
(12:05:56:093) [Vulkan2]   - maxPerStageDescriptorAccelerationStructures: 1048576
(12:05:56:093) [Vulkan2]   - maxPerStageDescriptorUpdateAfterBindAccelerationStructures: 1048576
(12:05:56:093) [Vulkan2]   - maxDescriptorSetAccelerationStructures: 1048576
(12:05:56:093) [Vulkan2]   - maxDescriptorSetUpdateAfterBindAccelerationStructures: 1048576
(12:05:56:093) [Vulkan2]   - minAccelerationStructureScratchOffsetAlignment: 128
(12:05:56:093) [Vulkan2] - VK_NV_mesh_shader:
(12:05:56:093) [Vulkan2]   - maxDrawMeshTasksCount => 65535
(12:05:56:093) [Vulkan2]   - maxTaskWorkGroupInvocations => 32
(12:05:56:093) [Vulkan2]   - maxTaskWorkGroupSize => [32;1;1]
(12:05:56:093) [Vulkan2]   - maxTaskTotalMemorySize => 16384
(12:05:56:093) [Vulkan2]   - maxTaskOutputCount => 65535
(12:05:56:093) [Vulkan2]   - maxMeshWorkGroupInvocations => 32
(12:05:56:093) [Vulkan2]   - maxDrawMeshTasksCount => [32;1;1]
(12:05:56:093) [Vulkan2]   - maxMeshTotalMemorySize => 16384
(12:05:56:093) [Vulkan2]   - maxMeshOutputVertices => 256
(12:05:56:093) [Vulkan2]   - maxMeshOutputPrimitives => 512
(12:05:56:093) [Vulkan2]   - maxMeshMultiviewViewCount => 4
(12:05:56:093) [Vulkan2]   - meshOutputPerVertexGranularity => 32
(12:05:56:093) [Vulkan2]   - meshOutputPerPrimitiveGranularity => 32
(12:05:56:093) [Vulkan2] - VK_EXT_pci_bus_info:
(12:05:56:093) [Vulkan2]   - pciDomain => 0
(12:05:56:093) [Vulkan2]   - pciBus => 1
(12:05:56:093) [Vulkan2]   - pciDevice => 0
(12:05:56:093) [Vulkan2]   - pciFunction => 0
(12:05:56:093) [Vulkan2] - VK_KHR_driver_properties:
(12:05:56:093) [Vulkan2]   - driver name: NVIDIA
(12:05:56:093) [Vulkan2]   - driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
(12:05:56:093) [Vulkan2]   - driver conformance version: 1.2.0.6:
(12:05:56:093) [Vulkan2]   - driver info: 471.11
(12:05:56:093) [Vulkan2] --- GPU 0 initialized ok
(12:05:56:117) Kombustor initialization ok.
(12:05:56:117) PhysX GPU info - device name => „@Ó - CUDA cores => 38
(12:05:56:148) WMI PC model: To Be Filled By O.E.M.
(12:05:56:148) WMI BIOS name: P4.30
(12:05:56:148) TDR Delay: 8 seconds
(12:05:56:148) [CHECKVERSION] checking for new version...
(12:05:57:225) [CHECKVERSION] your version of Kombustor is up to date
(12:06:04:574) WM_DPICHANGED - dpi_x => 96
A Vulkan test exits in a similar way.
(12:17:25:188) [Vulkan2] - VK_KHR_driver_properties:
(12:17:25:188) [Vulkan2]   - driver name: NVIDIA
(12:17:25:188) [Vulkan2]   - driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
(12:17:25:188) [Vulkan2]   - driver conformance version: 1.2.0.6:
(12:17:25:188) [Vulkan2]   - driver info: 471.11
(12:17:25:192) WM_DPICHANGED - dpi_x => 96
(12:17:25:356) [Vulkan2] --- GPU 0 initialized ok
(12:17:25:373) [ArtifactScanner] Artifact scanning for GPU overclocking.
The crash and exit can be reproduced with Kombustor versions v4.1.6 jun20 and v4.1.12 may21.
Additionally, Kombustor v4 will exit if Kombustor is open and the Windows DPI scaling is changed.
However, Kombustor version 3.5.2.1 jul15 does not seem to crash or exit to desktop.
Any ideas anyone? Thanks.
« Last Edit: July 16, 2021, 03:12:14 PM by Gam3r01 »
Re: Kombustor crashes with Windows DPI scaling enabled.
« Reply #1 on: August 13, 2021, 05:26:21 PM »
sorry for the delay, I will look at the issue as soon as possible!
« Reply #2 on: August 25, 2021, 11:56:14 AM »
I fixed the bug in Kombustor 4.1.13: https://www.geeks3d.com/furmark/kombustor/downloads/
