5900x OC issues, System Shutting off while not overheating please help
Started by SheltonCoolio, July 06, 2021, 09:44:24 AM
SheltonCoolio
These issue have persisted BEFORE attempting to overclock with completely other builds but to keep things simple this is my current setup : 5900x, 6900xt, asus tuf gaming x570 (wifi) on latest firmware and 32gb of ram. CPU being cooled with a Kraken Z73.***SPAM_LINKS_REMOVED***
So, to begin... As all of you know, the ryzen zen 3 processors get very hot. My 5900x on default bios settings shoots up to 90+ degrees just while starting up windows and running the startup ups for a few seconds to a minute. I understand this is somewhat "normal". To mitigate this I began overclocking and undervolting my CPU. I have tried with PBO2 and setting custom curves with starting values of 5 all the way up to 30 and no luck. Same thing. Maybe w 5 degree difference. Then I manually undervolted the cpu by .2-.26v from the original starting value of 1.416ish that it likes to sit at. I did the same thing using offset. Manual values and even trying auto. Nothing. PC STILL CRASHES WHEN under load aka playing a game. I have a Gskill 850W PSU, could this be the issue? It doesn't seem to overheat but I cannot check this as it does not have built in sensors.
Can anyone shed some light on why my pc suddenly crashes as soon as I try to open a game up?
Thank you for any help!
Edit 1: wanted to add that my temperatures drastically drop when I change to negative offset at around .25v but system still shuts off when I load up a game. This tells me it's definitely not an overheating issue. I have also confirmed this by setting all bios settings to default as stated above and it still crashes.
Boosted
Quote from: SheltonCoolio on July 06, 2021, 09:44:24 AM
I have almost the same System (5900x, 6900XT, 32GB Ram Kraken360mm LQ).
First off...yes the Cpu does get hot but not THAT hot usually.
Upon Startup i had Temps up to 90C as well...but fixed it.
How you may ask? Simple.
The Reason was bad Airflow...make sure your LQ has enough Room to blow out the warm Air.
Also download the NXZT Cam Software, which allows you to check the Temp of the Cooling Liquid.
It should always stay within 23-35C.
Anything above this and its either bad Airflow, poor Thermal Paste or a broken Cooler itself (which is unlikely).
Regarding PSU, this could indeed be a Reason.
850W is very tight as those Components can use over 750W, and thats without SSD, HDD ect.
I use a 1000W BeQuiet PSU and havent got any Problems.
So if you have the Chance to grab a bigger PSU for testing Purposes do it...
