Author Topic: Notepad++ 7.9.4 released  (Read 6845 times)
« on: March 15, 2021, 02:37:18 PM »
Notepad++ v7.9.4 Enhancements & bug-fixes:
1.  Upgrade Scintilla from v4.2.0 to v4.4.6.
2.  Fix DPI scaling broken while dragging Notepad++ into the 2nd monitor regression.
3.  Add "Find in Projects" feature.
4.   Fix project workspace changes lost on save cancel issue.
5.  Fix folder picker not being launched issue because provided directory is invalid.
6.  Fix network path (UNC path) not working in file dialog.
7.  Fix shortcut name more than 64 characters makes a menu entry empty name issue.
8.  Fix extension appending issue in file dialog.
9.  Fix file not turning to modified state (with Session Manager plugin) bug after its content being changed.
10. Add an option to mute all sounds in preferences dialog.
11. Make JSON auto-indent for brace.
- Download @ Geeks3D
- Download @ notepad-plus-plus
- Announcement @ notepad-plus-plus
Notepad++ 7.9.5 released
« Reply #1 on: March 26, 2021, 11:36:58 AM »
Notepad++ v7.9.5 bug-fixes:
1.  Fix Notepad++ not starting up due to SaveAsAdmin plugin (for installer package).
2.  Fix UNC path with quotes handling in folder & file Open/Save dialog.
3.  Fix file doesn't save as extension type on Windows 7.
