Author Topic: AMD Radeon Software Adrenalin 2020 Edition 20.11.3  (Read 1502 times)
« on: December 01, 2020, 12:37:08 AM »
Radeon Software Adrenalin 2020 Edition 20.11.3 Highlights
 Support For
  • Immortals: Fenyx Rising™
  • Vulkan® Ray Tracing Extensions
Added Vulkan® Support
  • VK_KHR_fragment_shading_rate
    • This extension provides the ability to change the shading rate per fragment. This extension allows for multiple pixels to be shaded via a single fragment shader invocation as opposed to the normal rate of one invocation per pixel.
  • VK_KHR_acceleration_structure
    • This extension provides acceleration structures for representing geometry that is spatially sorted. Acceleration structures are the most common way for quickly identifying potential ray intersections by ray tracing techniques.
  • VK_KHR_ray_tracing_pipeline
    • This extension introduces ray tracing pipelines along with new shader domains and an indirection table to link shader groups with acceleration structures.
  • VK_KHR_ray_query
    • This extension introduces ray queries, which can be used by any shader type outside of the optional dedicated ray tracing pipeline to return traversal results to the calling shader.
  • VK_KHR_deferred_host_operations
    • This extension defines the infrastructure and usage patterns for deferrable commands, which allows dependent extensions to defer their own operations. The VK_KHR_deferred_host_operations extension itself does not specify any commands as deferrable.
  • VK_KHR_pipeline_library
    • This extension introduces pipeline libraries. A pipeline library is a new special pipeline type that defines a set of pipeline states. It cannot be bound, rather it can be linked into other pipelines.
  • VK_KHR_shader_terminate_invocation
    • This extension indicates support for the SPV_KHR_terminate_invocation SPIR-V extension. The SPIR-V extension introduces a new instruction OpTerminateInvocation that allows a shader invocation to immediately terminate, which provides the behavior required by the GLSL discard statement.
Fixed Issues
  • Lower than expected performance may be experienced on Radeon™ RX 6000 series graphics products in Watchdogs:® Legion and Dirt™ 5.
  • Lower than expected performance may be experienced on Radeon™ RX 5000/500/400 series graphics products in Godfall™.
  • Godfall™ is not detected or listed in Radeon Software gaming tab.
  • Crysis™ Remastered may experience corruption on character models on Radeon™ RX 6800 Series graphics products.
  • Fixed some intermittent crashes found in Total War™ Saga: Troy and World of Warcraft®: Shadowlands.
  • World of Warcraft®: Shadowlands may fail to launch when DirectX®12 API is selected on Windows®7 system configurations.
  • Fixed some intermittent crashes found in Call of Duty®: Black Ops Cold War with DirectX® Raytracing enabled.
  • HDR on supported Windows 10 desktops might get disabled when DOOM® Eternal™ starts rendering in HDR mode.
  • Fixed issues found on Adobe™ Illustrator, Adobe™ Premier and FinalWire AIDA64.
  • Fixed corruption issues in Red Dead Redemption 2 in 1080p resolution on Radeon™ RX 6800 Series graphics products.
