Author Topic: OpenCL update Intel HD 5000  (Read 17841 times)
paulkruger
« on: November 11, 2020, 09:03:35 PM »
I just tried a function in a graphics program I have used for several years and it will not function with less than OpenCL 1.2  My system has V1.1 and no new driver updates are available since 2012.
How can I add newer OCL to my system? I have spent hours on google and am more confused than ever.
Thank you!
- CPU Name: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
- CPU Core Speed: 3,392 MHz
- CPU logical cores: 8
- Family: 6 - Model: 10 - Stepping: 9
- Physical Memory Size: 32,768 MB
- Operating System: Windows 7 64-bit build 7601 [Service Pack 1]
- PhysX Version: drivers not installed
   IvyBridge
    Provider:      Intel Corporation
    Version:      9.17.10.2932
    Date:         12/12/2012
    Device Details
    Adapter Compatibility:    Intel Corporation
    Video Processor:      Intel® HD Graphics Family
   Resolution:          1920 x 1080
   Bits Per Pixel:       l32
   Number of Colors       42,9496,7296
   Refresh Rate -          Current60 Hz
   Refresh Rate -          Maximum75 Hz
   Refresh Rate -          Minimum59 Hz
   Adapter DAC Type      Internal
   Adapter RAM          2.06 GB
   Availability          Running at full power
   StatusThis device is working properly.
   LocationPCI bus 0, device 2, function 0
   Device IdPCI\VEN_8086&DEV_0162&SUBSYS_2AD5103C&REV_09\3&11583659&0&10
Re: OpenCL update Intel HD 5000
« Reply #1 on: November 11, 2020, 09:31:26 PM »
Try this:
Intel® Graphics Driver for Windows* [15.33] Version: 15.33.53.5161 (Latest) Date: 10/23/2020
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
yuktubbs
« Reply #2 on: January 08, 2021, 03:39:17 AM »
Try this:
thanks, and thing helps
juankax
« Reply #3 on: May 11, 2021, 11:31:39 AM »
Thanks for the references, Stefan.
porno phim sex porno sex filmy cam porno
« Last Edit: May 19, 2021, 10:58:00 AM by juankax »
