Kombustor error
Started by Hopper64, November 11, 2020, 12:26:13 AM
Hopper64
Everything appears to work ok without that particular file. Should I wait on an update before using the application? Thanks again!
Quote from: Hopper64 on December 05, 2020, 10:09:58 AM
Except  Vulkan demos, right?
I will release a new Kombustor in the next days, but there's no warranty Vulkan demos will work with your RTX 30.
Hopper64
I was mainly concerned for the stress test to make sure my OC was stable. I wasn't sure if that file was a dependency, but it appears not to be so. I don't have experience with Vulcan demos or applications that use that programming interface.
Thanks for your kind assistance! Much appreciated!!
Hopper64
Just tried the new 4.1.9 Version of kombustor. Works great!! No need to alter the plugin file for Vulkan for the application to work. Thank you!!  :)
Thank you for the feedback. There was probably a bug that has been fixed these last days/weeks with all changes I made in the Vulkan plugin. Cool!
Hopper64
Hopper64
I'm getting crashes again with 4.1.10. Same issue, but changing the vulkan plugin file name fixes the problem as before. Newest Nvidia driver 460.89.
Log Name:      Application
Source:        Application Error
Date:          12/15/2020 7:42:23 PM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:
Description:
Faulting application name: MSI-Kombustor-x64.exe, version: 4.1.10.0, time stamp: 0x5fd758e1
Faulting module name: vulkan-1.dll, version: 1.2.148.1, time stamp: 0x5f32cab3
Exception code: 0xc000041d
Fault offset: 0x0000000000047fd2
Faulting process id: 0x154
Faulting application start time: 0x01d6d34cb1dd8267
Faulting application path: C:\Program Files\Geeks3D\MSI Kombustor 4 x64\MSI-Kombustor-x64.exe
Faulting module path: C:\Windows\SYSTEM32\vulkan-1.dll
Report Id: 00a390a7-2da6-46af-a60c-1d27b19ce871
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
It's really weird. I tested Kombustor 4.1.10 with a RTX 3060 Ti and it works fine (drivers: 460.89).
Could you do a clean re-install of your drivers?
Could you also test these apps that have a Vulkan module:
- GPU Caps Viewer ( https://www.geeks3d.com/20201202/gpu-caps-viewer-1-49-0-released/ )
- GPU-Z ( https://www.geeks3d.com/dl/show/10001 )
- GeeXLab ( https://www.geeks3d.com/dl/show/500 )
Or maybe it's a bad compilation of the Vulkan plugin...
No, don't re-install your drivers. I have some strange behaviors with my RTX 3060 Ti (like the current power draw (TDP) that is not displayed). I think that as soon as I can, I will recompile the whole project.
Hopper64
Thanks. I know GPU Z works fine. I have that installed already. Appreciate your help.
Hopper64
The new version 4.1.11.0 works fine. No errors here at all. Thank you!!
Quote from: Hopper64 on January 31, 2021, 03:37:15 PM
Great! Thanks for your feedback.
Hopper64
Well, this is odd. It's been working fine with 4.1.11.0 and nvidia driver 461.40, then the app crashed again through MSI AB with the following error. I clicked the kombustor icon again and it came right up. ??
Date:          2/3/2021 5:43:05 PM
Event ID:      1000
Level:         Error
Keywords:      Classic
User:          N/A
Computer:
Description:
Faulting application name: MSI-Kombustor-x64.exe, version: 4.1.11.0, time stamp: 0x6015835d
Faulting module name: vulkan-1.dll, version: 1.2.162.0, time stamp: 0x5fd3ef4d
Fault offset: 0x00000000000390cf
Faulting process id: 0x357c
Faulting application start time: 0x01d6fa864eda46e7
Report Id: a801aa89-afd5-44ca-b12c-491b18936bac
Event Xml:
Hopper64
This may be related to riva tuner. Just saw this post about RTSS and Vulcan. Updated to the RTSS RC and seems to be working correctly.
Post #2987.
https://forums.guru3d.com/threads/rtss-6-7-0-beta-1.412822/page-150
Interesting info. I rarely use rivatuner / msi afterburner during my tests and benchmarks, that's why I didn't see this issue. Will try to launch afterburner more often in the future.
Hopper64
Yes. I didn't even consider a connection between the 2 until I see that post. I use MSI AB and RTSS to OC my card/monitor stats in game.
