Kombustor error
Started by Hopper64, November 11, 2020, 12:26:13 AM
Hopper64
Using latest windows 64, 20h2, kombustor crashes with the following error. Latest version of kombustor. Any ideas? Thanks.
Log Name: Application
Source: Application Error
Date: 11/8/2020 1:59:18 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer:
Description:
Faulting application name: MSI-Kombustor-x64.exe, version: 4.1.7.0, time stamp: 0x5f6daf40
Faulting module name: vulkan-1.dll, version: 1.2.141.0, time stamp: 0x5ed9b44f
Exception code: 0xc000041d
Fault offset: 0x00000000000469a2
Faulting process id: 0xddc
Faulting application start time: 0x01d6b609a2c1a9ad
Faulting application path: C:\Program Files\Geeks3D\MSI Kombustor 4 x64\MSI-Kombustor-x64.exe
Faulting module path: C:\Windows\SYSTEM32\vulkan-1.dll
Report Id: 0fb7c4db-f512-40fa-bfec-c4a217089c99
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
Hopper64
BTW-Using a new EVGA 3090 Ultra.
Do you have something in Kombustor log file (_kombustor_log.txt) ?
I'm still with win10 v2004 but I will update to v20H2 asap.
Hopper64
Don't see any specific error in the log file. Tried it again today with the same application error:
Date:          11/11/2020 7:51:14 AM
Event ID:      1000
Level:         Error
Keywords:      Classic
User:          N/A
Computer:
Description:
Faulting process id: 0x39f0
Faulting application start time: 0x01d6b831b70da9c9
Report Id: 3ed19f73-c8af-4a42-aed2-3623f164bf18
Event Xml:
Ok, I couldn't resist to test, so I updated my system with latest win10 v20H2.
I tested Kombustor 4.1.7 with a RTX 2070 + latest GeForce 457.30, and everything seems ok, no crash.
I don't have yet a RTX 30 GPU, so one thing you can do is to rename the GPU monitoring plugin, maybe it's the source of the crash. The GPU monitoring plugin is located here:
MSI_Kombustor_FOLDER/plugins/plugin_gxc_gpumon_x64.dll
Just rename it to disable it.
What is your graphics driver?
Hopper64
Driver 457.30.
I added a 1 to the front of the file. No change.
Date:          11/11/2020 9:07:41 AM
Event ID:      1000
Level:         Error
Keywords:      Classic
User:          N/A
Computer:
Description:
Faulting module name: zx_x64.dll, version: 0.0.0.0, time stamp: 0x5f6db46e
Exception code: 0xc0000005
Fault offset: 0x0000000000041e4d
Faulting process id: 0x1364
Faulting application start time: 0x01d6b83c65be5fbb
Faulting module path: C:\Program Files\Geeks3D\MSI Kombustor 4 x64\zx_x64.dll
Report Id: 0e411e8b-2b04-46e1-8d69-fbbd43132d9b
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
Try 457.33 which is from a different driver branch.
457.33 VK456_14-10
457.30 r457_22-3
Hopper64
I don't see a hotfix 457.33 driver available. Where would you download that?
Hopper64
So I download that driver  and install over my existing 457.30 regular GeForce driver?
Yes, should be no problem.
If you don't like a newer driver for whatever reason, you can always quickly roll back via device manager.
Hopper64
I downloaded and looked at the installation files. It will change my existing installation including GeForce experience. I would prefer not to do that if possible. Any other ideas? Thanks!
If you are not in a hurry, you can recheck with the "RTX 3060 Ti" launch driver on December 2nd
Hopper64
I'll probably wait on that and report back. I need a water block for this 3090 FTW EVGA card anyway. Hope EK comes out with something soon. Prefer to have it under water to let it really stretch its legs. Thanks!!
Hopper64
Just tried new driver 357.51. Still the same error:
Date:          12/2/2020 11:25:05 AM
Event ID:      1000
Level:         Error
Keywords:      Classic
User:          N/A
Computer:
Description:
Faulting process id: 0xee0
Faulting application start time: 0x01d6c8d00f780c5a
Report Id: 135fd08e-b4ec-4459-b9db-350be956e16d
Event Xml:
There is something I didn't understand: do you manage to launch Kombustor and see the main user interface?
Looks like there is an issue with Vulkan demos. Can you start an OpenGL demo?
Hopper64
I do not see the main interface actually. I just see the cursor of the mouse turn and nothing else.
ok so try to rename the Vulkan plugin to disable it:
{Kombustor folder}/plugins/plugin_gxc_vulkan2_x64.dll
Can you start Kombustor after that change?
Hopper64
Yes! That worked. Renaming the vulkan plugin worked. I didn't know there was a new version of Kombustor available. Downloaded that 4.1.8.0 and still had the same issue, but I just placed a (1) in front of the plugin file--- /plugins/1plugin_gxc_vulkan2_x64.dll and all works as intended. Thanks for the help!!  :)
Cool!
There must be a bug in my Vulkan code with new RTX 30 series. But I still don't have a RTX 30 card and then I can't reproduce and fix the bug.
