Author Topic: Irfanview 4.56 released  (Read 1888 times)
« on: October 22, 2020, 04:37:59 PM »
A new version of Irfanview, one of the most popular image viewer for Windows, is available.
- Updated Video PlugIn (improved Win10 compatibility, new player for MP3/FLAC)
- Option to play all audio formats in main window (Properties->Video/Sound)
- Option to change hotkeys for menus: Right mouse click on menu item
- New option in Paint dialog: Fill rect/ellipse with transparent color
- New "Edit->Insert Watermark" option: Use color to highlight an area
- Option to disable mouse wheel for file browsing (Properties->Browsing)
- New SVG PlugIn (Thanks to seppesol)
- New XCF PlugIn (Thanks to Jacek SQ6KBQ)
- New JPG option: Use QuantSmooth loading (PlugIn, thanks to Ilya Kurdyukov)
- Option for page/frame filename suffix in Multipage-Extract dialog
- CTRL + "Save-As" icon on toolbar calls the "Save" menu
- New option in Advanced batch dialog: Add Border/Frame
- New option in Insert Text dialog: Settings for Outline-1 effect (Rainbow)
- New paste option: Change paste counter (Edit->Paste special)
- New shapes in Hexagon dialog: Ellipse, Cloud; Spiral (thanks to Rod Stephens)
- New option in Hexagon/Shadow dialog: Background transparency
- Support for PSB format (Photoshop files)
- Context menu added to EXIF dialog (Copy only selected lines)
- New placeholder: $c (Compression text from Image->Info dialog)
- Program icon updated
- New Paint dialog icons (Thanks to Michael Grosberg)
- CLP format moved to FORMATS PlugIn
- JP2 PlugIn loading bugs fixed (thanks to Phung Duc Luan and Linhlhq)
- B3D and XCF PlugIn loading bugs fixed (thanks to Zhe Wang)
- Formats PlugIn bugs fixed (XPM,XBM,CR2,HDR,WBMB,FITS,DDS) (thanks to nhiephon)
- MNG PlugIn loading bug fixed (thanks to zhazha crack)
- Several PlugIns are changed/updated, please install the newest versions:
  Download from: https://www.irfanview.com/plugins.htm
Links
- Download Irfanview 64-bit @ Geeks3D
- Download Irfanview plugins 64-bit @ Geeks3D
- Download Irfanview plugins 64-bit @ irfanview
