Author Topic: AMD Radeon Software Adrenalin 2020 Edition 20.9.2  (Read 2574 times)
« on: September 29, 2020, 08:59:09 PM »
Radeon Software Adrenalin 2020 Edition 20.9.2 Highlights
Support For
  • STAR WARS™: Squadrons
Added Vulkan™ Support
  • VK_KHR_buffer_device_address
    • This extension is used to query the device address of a buffer to allow for shader access to that buffer’s storage via the SPV_KHR_physical_storage_buffer SPIRV extension.
  • VK_EXT_robustness2
    • This extension provides stricter restrictions for handling reads and writes that are out of bounds. It specifies that out-of-bounds reads must return zeros and out-of-bounds writes must be discarded. This extension also adds support for null descriptors.
  • VK_EXT_shader_image_atomic_int64
    • This extension extends existing 64-bit integer atomic support to images, which provides more efficient access than buffers. This allows applications to quickly improve their performance with minor changes to their code.
Fixed Issues
  • Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
  • Radeon FreeSync may fail to enable after updating Radeon Software without a system reboot.
  • Screen flickering may be observed while MSI Afterburner™ is running or enabled on the system.
  • X-Plane 11™ may experience an application hang or crash when using the Vulkan® API.
  • DOOM™ VFR may experience corruption or artifacting in game on Radeon RX 5000 series system configurations.
  • Performance metrics overlay may fail to open or appear after the system wakes from sleep.
  • Call of Duty®: WWII may experience black textures on the ground or walls in zombies game mode.
  • Blocky corruption may be observed in Detroit: Become Human™ on some Radeon RX 5000 series graphics products.
  • Using the Movies&TV application to edit video clips may result in green corruption in the clips.
  • Performance metrics may report incorrect values for current VRAM usage after an extended period of gameplay.
  • With HDR enabled, Windows® desktop may experience flickering, and performing a task switch while in a game may cause colors to become washed out or over saturated.
  • World of Warcraft™ may experience corruption issues with anti-aliasing enabled on DirectX®12 API.
  • Launching Radeon Software after a driver upgrade, may cause the Auto OC dialogue to appear with “0 Mhz” when the Auto OC feature has been previously enabled on Radeon RX Vega series graphics products.
