Author Topic: NVIDIA GeForce Studio driver 456.38  (Read 2232 times)
« on: September 17, 2020, 03:14:14 PM »
NVIDIA Studio Drivers provide artists, creators, and 3D developers the best performance and reliability when working with creative applications. To achieve the highest level of reliability, Studio Drivers undergo extensive testing against multi-app creator workflows and multiple revisions of the top creative applications from Adobe to Autodesk and beyond.
 Applications
 The September NVIDIA Studio Driver provides optimal support for the latest creative application updates including D5 Render, SheenCity Mars, and the new NVIDIA Broadcast App.
 In addition, this release also provides support for the new GeForce RTX 3080 and 3090 GPUs. Powered by NVIDIA'S second-generation RTX architecture, with ray tracing up to twice as fast and five times faster motion blur rendering, utilizing third generation tensor cores to power next-gen AI-powered tools
 Learn more about these new releases in NVIDIA's Studio Driver article here.
https://de.download.nvidia.com/Windows/456.38/456.38-notebook-win10-64bit-international-nsd-whql.exe
 https://kr.download.nvidia.com/Windows/456.38/456.38-notebook-win10-64bit-international-nsd-dch-whql.exe
 https://us.download.nvidia.com/Windows/456.38/456.38-win10-nsd-release-notes.pdf
 https://tr.download.nvidia.com/Windows/456.38/456.38-notebook-win10-64bit-international-dch-whql.exe
 https://it.download.nvidia.com/Windows/456.38/456.38-notebook-win10-64bit-international-whql.exe
 https://fr.download.nvidia.com/Windows/456.38/456.38-notebook-win7-64bit-international-whql.exe
 https://us.download.nvidia.com/Windows/456.38/456.38-notebook-win8-win7-64bit-international-whql.exe
 https://us.download.nvidia.com/Windows/456.38/456.38-win10-win8-win7-release-notes.pdf
Besides GeForce Ampere, this driver adds support for an unannounced Turing GPU
NVIDIA_DEV.1FB0 = "NVIDIA DGX Display"
« Last Edit: September 17, 2020, 04:06:49 PM by Stefan »
NVIDIA Quadro driver 456.38
« Reply #1 on: September 18, 2020, 04:56:31 PM »
 Release 455 is a Quadro New Feature (QNF) driver. QNF drivers provide users the flexibility to try new features made available outside the launch cycle of longer-lived Optimal Driver for Enterprise (ODE) branches. QNF drivers are tested for workstation environments and are recommended only for those users who need specific features mentioned in the release highlights or release notes.
 Quadro Release 455 comprises the entire suite of Quadro features, as well as all NVIDIA Studio Driver features.
 For the most stable and fully supported enterprise driver please use the ODE graphics drivers downloadable from the main NVIDIA driver download page.
 New in Release R455 U1
 New Studio Features
  • NVIDIA Deep Learning Super Sampling (DLSS) support added for D5 Render and SheenCity Mars.
  • DLSS is an AI super resolution algorithm that utilizes RTX Tensor Cores to boost frame rates, increasing viewport interactivity while maintaining visual fidelity.
  • Support for NVIDIA Broadcast application, which uses the dedicated Tensor cores in Quadro RTX GPUs to offer:
    • Noise Removal: removes background noise from microphone feed.
    • Virtual Background: removes the background from webcam feed and replace it with an alternative image, Windows app, a game, or subtle blur.
    • Auto Frame: zooms in on the user and applies AI to track head movements, maintaining centered frame.
 CUDA 11.1 Support
  • Added new PTX Compiler static library that allows compilation of PTX programs using supplied APIs.
  • Added the 7.1 version of the Parallel thread Execution instruction set architecture (ISA).
  • Unified programming model for:
    • async-copy
    • async-pipeline
    • async-barrier (cuda::barrier)
  • Added hardware accelerated sparse texture support.
  • Added support for read-only mapping for cudaHostRegister.
  • Multi-threaded launch to different CUDA streams is supported.
  • CUDA Graphs enhancements:
    • improved graphExec update
    • external dependencies
    • extended memcopy APIs
    • presubmit
  • Introduced new system level interface using /dev based capabilities for cgroups style isolation with Multi-instance GPU (MIG).
  • Improved MPS error handling when using multi-GPUs.
  • Users can now configure and query the per-context time slice duration for a GPU via nvidia-smi.
  • Improved detection and reporting of unsupported configurations.
 Fixed Issues in Release R455 U1
  • [PTC Creo]: Improved the application wireframe performance.
 Open Issues in Release R455 U1
  • [Alchemist]: The application crashes when either changing the display resolution or switching to another display with a different resolution.
  • To workaround, avoid changing the resolution, or disconnecting from or connecting to an external display with the application opened.
 https://cn.download.nvidia.com/Windows/Quadro_Certified/456.38/456.38-win10-quadro-release-notes.pdf
 https://uk.download.nvidia.com/Windows/Quadro_Certified/456.38/456.38-quadro-desktop-notebook-win10-64bit-international-whql.exe
 https://pl.download.nvidia.com/Windows/Quadro_Certified/456.38/456.38-quadro-desktop-notebook-win10-64bit-international-dch-whql.exe
