Geexlab linux 0.38 cant drop xml files in
Started by gravisxv, September 14, 2020, 03:29:29 PM
gravisxv
I started doing some benches on linux, and i havent found any issue so far in raspbian. As soon as i tried latest Manjaro xfce it seems the xml files are completely ignored when dropped on the program. Is there a fast way to load the xml via command line??  :-[
gxvtronics  - hw-tutorials-anime-diy gxvtronics.altervista.org
Yes you can load the xml file via the command line:
$ ./GeeXLab /demofile=\"path_to_file.xml\"
Let me know.
gravisxv
Thanks its working fine via terminal 8). Im thinking the problem could be somewhere in xfce as the geexlab windows loses focus but im not sure 100%.
baryluk
gravisxv. The drag and drop of xml files works for my on Linux. I am using Mate with Caja file manager, and it works.
Are you using Thunar as a file manager on xfce?
gravisxv
baryluk
Quote from: gravisxv on March 18, 2021, 01:30:43 AM
Yes, still doesnt work in latest manjaro
I see.
I can reproduce the issue with Thunar 4.16.3
Works fine with Caja 1.24.0
