Author Topic: Compiler Explorer  (Read 1716 times)
Compiler Explorer
« on: August 06, 2020, 11:32:10 AM »
Compiler Explorer is an interactive compiler. The left-hand pane shows editable C, C++, Rust, Go, D, Haskell, Swift, Pascal (and some more!) code. The right, the assembly output of having compiled the code with a given compiler and settings. Multiple compilers are supported, and the UI layout is configurable (thanks to GoldenLayout). There is also an ispc compiler ? for a C variant with extensions for SPMD.
- https://godbolt.org
- https://github.com/compiler-explorer/compiler-explorer
Compiler Explorer
