Author Topic: mimalloc: general purpose allocator with excellent performance  (Read 1946 times)
mimalloc (pronounced "me-malloc") is a general purpose allocator with excellent performance characteristics. Initially developed by Daan Leijen for the run-time systems of the Koka and Lean languages.  It is a drop-in replacement for malloc and can be used in other programs without code changes.
Main features:
- small and consistent: the library is about 6k LOC using simple and consistent data structures. This makes it very suitable to integrate and adapt in other projects. For runtime systems it provides hooks for a monotonic heartbeat and deferred freeing (for bounded worst-case times with reference counting).
- free list sharding: the big idea: instead of one big free list (per size class) we have many smaller lists per memory "page" which both reduces fragmentation and increases locality -- things that are allocated close in time get allocated close in memory. (A memory "page" in mimalloc contains blocks of one size class and is usually 64KiB on a 64-bit system).
- eager page reset: when a "page" becomes empty (with increased chance due to free list sharding) the memory is marked to the OS as unused ("reset" or "purged") reducing (real) memory pressure and fragmentation, especially in long running programs.
- secure: mimalloc can be built in secure mode, adding guard pages, randomized allocation, encrypted free lists, etc. to protect against various heap vulnerabilities. The performance penalty is usually around 10% on average over our benchmarks.
- first-class heaps: efficiently create and use multiple heaps to allocate across different regions. A heap can be destroyed at once instead of deallocating each object separately.
- bounded: it does not suffer from blowup [1], has bounded worst-case allocation times (wcat), bounded space overhead (~0.2% meta-data, with at most 12.5% waste in allocation sizes), and has no internal points of contention using only atomic operations.
- fast: In our benchmarks (see below), mimalloc outperforms other leading allocators (jemalloc, tcmalloc, Hoard, etc), and usually uses less memory (up to 25% more in the worst case). A nice property is that it does consistently well over a wide range of benchmarks. There is also good huge OS page support for larger server programs.
- https://github.com/microsoft/mimalloc
