The information on Tiger Lake platform is incorrect on GPU Caps Viewer.
Started by Phoebe, June 29, 2020, 04:52:24 AM
Phoebe
The GPU and Config are blank and incorrect on Tiger lake platform, please refer to the picture(https://imgur.com/6JphiSg).
Do the new CPU haven't include in the data base? Could the programer add Tiger Lake into data base?
Apparently you are the first Tigerlake user.
Does GPU-Z show more infos?
Otherwise try Intel Extreme Tuning Utility (Intel XTU)
Where is the driver download site for your system?
Phoebe
Quote from: Stefan on June 29, 2020, 09:17:00 AM
The information on GPU-Z is also incorrect. And the system unable to start Intel XTU because the driver isn't present.
I understood the new CPU haven't include in database.
However I just want to know when will programmer plan to add the new Intel GPU into database.
And I already saw you have shared the new Intel GPUs ID to JeGX, thank you very much.
Quote from: JeGX on June 29, 2020, 10:23:37 AM
Xe GPU?
Do you have more details on the number of EUs?
My GPU is not Xe GPU. My GPU ID is 9A49.
I can add your GPU to GPU Caps Viewer and other GPU tools but I need some information:
- device ID = 0x9A49  - OK
- GPU name =  "Intel(R) UHD Graphics" - OK
- number of UEs = ???   - MISSING
According to this news, it looks like the 0x9A49 is an Intel Xe Graphics...
Phoebe
The details of the numbers of EUS below are what I got on Intel document.
INTEL_DEV_9A49 = "Intel(R) UHD Graphics"
i7= EUS:96, i5= EUS:80
INTEL_DEV_9A78 = "Intel(R) UHD Graphics"
i3= EUS:48
Not sure the news is correct since I didn't get such information from Intel.
Frank
The up to date GPU Caps Viewer 1.46.1.0 still no Core config of 0x9A78
Could you help add it into next release?
- device ID = 0x9A78
- number of EUs = 48
Quote from: Frank on October 13, 2020, 09:51:04 AM
No problem, I will add GPU data for devID 9A78.
Thanks for the info!
Frank
The up to date GPU Caps Viewer 1.47.2.0 still no Core config of 0x9A78
andy_chen
Hi JeGX,
Would you please also help to add Tiger lake H platform information as below?
- device ID = 0x9A60 / 0x9A68 / 0x9A70
- number of EUs = 32 / 16 / 32
*These devices are use the same GPU name
Quote from: andy_chen on December 05, 2020, 08:40:34 AM
Yes Andy, these devices will be added in the next update of GPU Caps Viewer.
andy_chen
Hi JeGX,
Sorry, I forgot to provide TGL-H of TDP value. Would you please help to add it into the next release?
- TDP = 45W
