Computer restarts in 3 seconds but stays on with video cable removed. PSU?
Started by wimafrank, June 17, 2020, 05:20:24 PM
wimafrank
Sorry I don't know if the same question has been asked/answered before. I searched but could not find a similar situation.
When I run FurMark, the computer restarts in a few seconds with the HDMI cable connected. If I remove the cable, the computer stays on. Is that a PSU issue or the cable/monitor?
Thanks a lot in advance.
Frank
Looks like a PSU issue. What is your GPU model? And your PSU model?
wimafrank
Thanks a lot JeGX,
GPU:
ASUS Dual GeForce RTX 2080 Ti DirectX 12 DUAL-RTX2080TI-O11G 11GB 352-Bit GDDR6 PCI Express 3.0 HDCP Ready SLI Support Video Card
PSU:
NEW 800W 800 850 Watt 850W LED Large Quiet Fan ATX Power Supply SATA 12V PCI-E PSU by COOLFANS
Frank
Never heard about coolfans brand.
A RTX 2080 Ti can draw a lot of power when FurMark is running and your PSU seems a bit suspect for me.
Do you have the possibility to test with a stronger PSU like a Corsair or a Seasonic one?
wimafrank
Followed your advice and tried a different 450W PSU, and the FurMark finished run without issues. So the previous PSU is not powerful enough. Thank you so much JeGX!
