Author Topic: GPU Caps Viewer 1.45.0.0 released  (Read 18485 times)
« on: June 02, 2020, 02:03:30 PM »
GPU Caps Viewer 1.45.0.0 has been released.
Release notes and download links:
https://www.geeks3d.com/20200602/gpu-caps-viewer-1-45-0-released/
Version 1.45.0.0 - 2020.06.01
+ GPU panel: added raytracing and tensor cores on NVIDIA Turing+ GPUs.
! GPU panel: Texture and pixel fillrates: boost clock speed is used instead of base clock speed.
+ GeeXLab demos: added new Vulkan demos based on the new Vulkan2 plugin
 (demos based on the first Vulkan plugin have been removed). A new mesh shader
 demo (Vulkan) for NVIDIA Turing GPUs has been added.
! updated with latest GeeXLab SDK libs (GeeXLab 0.33.0.0).
! updated: GPU Shark 0.17.0.0
! updated: ZoomGPU 1.26.0 (GPU monitoring library).
GPU Caps Viewer + GeForce RTX 2070
GPU Caps Viewer 1.45.1.0 released
« Reply #1 on: June 03, 2020, 05:21:56 PM »
A new version of GPU Caps Viewer has been released:
https://www.geeks3d.com/20200602/gpu-caps-viewer-1-45-0-released/#20200603
Version 1.45.1.0 - 2020.06.03
+ GPU panel: added more details about Radeon GPUs (ASIC type, CUs and WGPs).
! updated: GPU Shark 0.17.1.0
! updated: ZoomGPU 1.26.1 (GPU monitoring library)
  with AMD AGS 5.4.1.
GPU Caps Viewer + Radeon RX 5500 XT
Re: GPU Caps Viewer 1.45.0.0 released
« Reply #2 on: June 29, 2020, 10:25:14 AM »
Here are the device IDs for preliminary support of future Intel GPUs
 Via v26.20.100.8018
; ICL
INTEL_DEV_8A51 = "Intel(R) Iris(R) Plus Graphics"
INTEL_DEV_8A52 = "Intel(R) Iris(R) Plus Graphics"
INTEL_DEV_8A5A = "Intel(R) Iris(R) Plus Graphics"
INTEL_DEV_8A5B = "Intel(R) UHD Graphics"
INTEL_DEV_8A57 = "Intel(R) UHD Graphics"
INTEL_DEV_8A56 = "Intel(R) UHD Graphics"
INTEL_DEV_8A5C = "Intel(R) Iris(R) Plus Graphics"
INTEL_DEV_8A5D = "Intel(R) UHD Graphics"
INTEL_DEV_8A59 = "Intel(R) UHD Graphics"
INTEL_DEV_8A58 = "Intel(R) UHD Graphics"
INTEL_DEV_8A53 = "Intel(R) Iris(R) Plus Graphics"
INTEL_DEV_8A54 = "Intel(R) Iris(R) Plus Graphics"
; TGL
INTEL_DEV_9A49 = "Intel(R) UHD Graphics"
INTEL_DEV_9A40 = "Intel(R) UHD Graphics"
INTEL_DEV_9A59 = "Intel(R) UHD Graphics"
INTEL_DEV_9A60 = "Intel(R) UHD Graphics"
INTEL_DEV_9A68 = "Intel(R) UHD Graphics"
INTEL_DEV_9A70 = "Intel(R) UHD Graphics"
INTEL_DEV_9A78 = "Intel(R) UHD Graphics"
; LKF
INTEL_DEV_9840 = "Intel(R) UHD Graphics"
INTEL_DEV_9841 = "Intel(R) UHD Graphics"
INTEL_DEV_9842 = "Intel(R) UHD Graphics"
; EHL
INTEL_DEV_4541 = "Intel(R) UHD Graphics"
INTEL_DEV_4551 = "Intel(R) UHD Graphics"
INTEL_DEV_4571 = "Intel(R) UHD Graphics"
; DG1
INTEL_DEV_4905 = "Intel(R) UHD Graphics"
INTEL_DEV_4906 = "Intel(R) UHD Graphics"
INTEL_DEV_4907 = "Intel(R) UHD Graphics"
; RKL
INTEL_DEV_4C80 = "Intel(R) UHD Graphics"
INTEL_DEV_4C8A = "Intel(R) UHD Graphics"
INTEL_DEV_4C81 = "Intel(R) UHD Graphics"
INTEL_DEV_4C8B = "Intel(R) UHD Graphics"
« Reply #3 on: June 29, 2020, 10:32:28 AM »
Thanks Stefan, I will add them in the GPU database asap!
enigma9o7
« Reply #4 on: August 28, 2020, 07:31:08 PM »
I tried both the installer and the gpu-caps-viewer in the zip, neither appears to work under XP, I'm told it's not a valid Win32 application.
« Reply #5 on: August 28, 2020, 07:52:00 PM »
Try version 1.37
https://www.geeks3d.com/20171031/gpu-caps-viewer-1-37-0-released/
enigma9o7
« Reply #6 on: August 28, 2020, 08:28:21 PM »
Thanks, works!
Should I ignore updates from now on, or do you plan to restore XP compatibility in future versions?
« Reply #7 on: August 30, 2020, 10:27:26 PM »
Some more future Intel GPUs in driver 27.20.100.8435
http://download.windowsupdate.com/d/msdownload/update/driver/drvs/2020/08/bb82c61b-983d-4489-a893-3f3418b0945d_2f769abfcf5e5a41f84e5bcdc000568fa438f804.cab
; TGL
INTEL_DEV_9A49 = "Intel(R) Iris(R) Xe Graphics"
INTEL_DEV_9A40 = "Intel(R) Iris(R) Xe Graphics"
INTEL_DEV_9AC9 = "Intel(R) UHD Graphics"
INTEL_DEV_9AF8 = "Intel(R) UHD Graphics"
INTEL_DEV_9AC0 = "Intel(R) UHD Graphics"
INTEL_DEV_9AD9 = "Intel(R) UHD Graphics"
; LKF
; EHL
; JSL
INTEL_DEV_4E51 = "Intel(R) UHD Graphics"
INTEL_DEV_4E61 = "Intel(R) UHD Graphics"
INTEL_DEV_4E71 = "Intel(R) UHD Graphics"
; DG1
INTEL_DEV_4908 = "Intel(R) UHD Graphics"
; RKL
INTEL_DEV_4C8C = "Intel(R) UHD Graphics"
INTEL_DEV_4C90 = "Intel(R) UHD Graphics"
INTEL_DEV_4C9A = "Intel(R) UHD Graphics"
