Author Topic: TechPowerUp GPU-Z 2.32.0 Released  (Read 11506 times)
« on: May 29, 2020, 05:27:07 PM »
  GPU-Z is a lightweight utility designed to give you all information about your video card and GPU.
     Version History     v2.32.0 (May 29th, 2020)
  • Added NVIDIA per-rail voltage and power monitoring
  • Fixed WDDM 2.7 Hardware Accelerated GPU Scheduling readout in Advanced Tab to report "Disabled, not supported" instead of "Unknown (8)" on Windows 10 2004 with AMD graphics card
  • Added support for Intel Comet Lake 10th Generation CPUs
  • Added support for AMD Radeon Pro W5700X, WX 4170
  • Added support for GTX 1650 Ti Mobile (TU116-A), NVIDIA Tesla V100S-PCIE-32GB
Re: TechPowerUp GPU-Z 2.32.0 Released
« Reply #1 on: June 02, 2020, 01:57:04 PM »
Updated in the download zone:
- GPU-Z @ Geeks3D
Tested with my RTX 2070:
GPU-Z , new hardware sensors on RTX 2070
  • Full Member
« Reply #2 on: June 02, 2020, 07:39:16 PM »
New "Power Monitoring" types on EVGA NV GeForce GTX 980 Ti SC+!!
<3 :D
« Reply #3 on: June 02, 2020, 08:39:26 PM »
Could you post the same sensors screenshot but this time with FurMark running in background? I'm curious to see the different power values.
  • Full Member
« Reply #4 on: June 02, 2020, 11:02:41 PM »
100% power consumption
110% power consumption
« Reply #5 on: June 03, 2020, 04:38:11 PM »
Thanks!
Do you know what is MVDDQ power draw?
  • Full Member
« Reply #6 on: June 03, 2020, 08:04:21 PM »
Thanks!
:D This means "Graphics memory power consumption". Graphics memory is VRAM. :)
