Author Topic: Furmark minimum hardware?  (Read 10715 times)
Paintufast
« on: May 29, 2020, 06:05:18 AM »
Hello, I have a quick question. I am trying to build a GPU testing rig that can run multiple GPU at once. I am currently using a OONDA d1800 BTC MOBO, with a very low end processor and ram. When I run Furmark I notice that the screen is laggy and the MHz on the cards never goes over like 300mhz.
I am just trying to understand my assumption that this is caused by the system being too slow. And if that is the case, what I would need to upgrade to fix it. Is there a listing of minimum requirements for Furmark to run? I am using Windows 10.
I’m not positive what the specific cpu and ram amounts are on this setup.
Re: Furmark minimum hardware?
« Reply #1 on: May 29, 2020, 11:33:36 AM »
FurMark is a graphics benchmark.
You need a motherboard with SLI support to test graphics performance of multiple GPUs.
With your mining motherboard i suggest you try compute benchmarks like CompuBench or SiSoft Sandra
