Furmark not reading nvidia GPU voltage as of GPU-Z 2.30
Started by ssateneth, March 22, 2020, 02:22:31 AM
ssateneth
Remember this thread? https://www.geeks3d.com/forums/index.php?topic=6001.0
Same thing happened. The devs changed one of the sensor names for nvidia voltage as of GPU-Z 2.30, so now Furmark cannot read it. Recommend this be patched soon. Some other things were renamed too. See patch notes here.
https://www.techpowerup.com/download/techpowerup-gpu-z/
Thank you.
MarcoHarn
#2
Hi...while resolving this issue for myself i came across a good conversation and i was able to resolve it. I can see the case i similar here. You are hitting the power limit perf cap there. As temps increase, so does voltage and heat,as voltage goes up, so does the required power. When you hit the power limit prescribed in the bios for the GPU, it will throttle the core and voltage to bring it back down where it should be.A couple of things might help, assuming you can use Afterburner or PrecisionX on a mobile GPU.
1. Create a custom fan curve to keep the GPU cooler
2. Increase the power limit slider in MSI AB / EVGA PCX
surface mount assembly
