Author Topic: PhysX FluidMark 1.5.3 released  (Read 16822 times)
« on: March 16, 2020, 04:03:09 PM »
A maintenance version of FluidMark is available (previous version 1.5.2 has been released 7 years ago...).
FluidMark 1.5.3 is still based on PhysX 2.8.4 SDK!
Release notes and download:
- https://www.geeks3d.com/20130308/fluidmark-1-5-1-physx-benchmark-fluid-sph-simulation-opengl-download/#20200316
Changelog
Version 1.5.3 - 2020-03-15
! score submissions disabled.
! fixed a minor bug in fullscreen mode (in some cases, the menu bar was displayed).
! recompiled with VS2017
! updated: ZoomGPU 1.25.1 (GPU monitoring library).
. Maintenance release
PhysX FluidMark
  • Full Member
Re: PhysX FluidMark 1.5.3 released
« Reply #1 on: March 17, 2020, 01:05:35 PM »
My GPU GTX 980 Ti SC+ gets only 55% GPU usage at default 1080p preset running Windows 10 1909 and CPU i7-4790K@4.4GHz because CPU (very) high bound is PROBLEM.
-> Result average ~112fps
But can you remove CPU bound for GPU Physx test?
« Reply #2 on: March 17, 2020, 06:26:03 PM »
Tick options "Multithread PhysX" + "Async mode"
  • Full Member
« Reply #3 on: March 19, 2020, 04:09:56 PM »
Thank. I get ~536 fps :) but 178 sps (178 fps for physics only).
I got the ghost glitch at 1080p preset for impact performance but no any glitch at user's settings.
Please should eliminate ghost for presets.
« Reply #4 on: March 23, 2020, 09:49:33 AM »
What is the ghost glitch exactly?
I will remove the ghost effect in all benchmark presets.
  • Full Member
« Reply #5 on: March 23, 2020, 10:15:52 AM »
Ghost glitches - edit: sorry I forgot. GeForce 441.87 driver with HQ settings
« Last Edit: March 23, 2020, 10:42:54 AM by nuninho1980 »
« Reply #6 on: March 23, 2020, 03:53:15 PM »
I decided to no remove the ghost effect. It's part of FluidMark since the beginning: it's an additional pixel shader effect and it does not change the score.  This effect is enabled in Preset:1080 and Preset:720 and you can enable it manually with "More graphics load" checkbox.
PhysX FluidMark 1.5.4 released
« Reply #7 on: March 23, 2020, 03:55:20 PM »
A maintenance version of FluidMark is available.
https://www.geeks3d.com/20130308/fluidmark-1-5-1-physx-benchmark-fluid-sph-simulation-opengl-download/#20200323
Version 1.5.4 - 2020-03-23
* fixed a bug in fullscreen mode (the keyboard was effectless!).
